Factory Oil Pressure Gauge
on my oil press. gauge, what should it be reading for an engine to be healthy? I know it doesn't have numbers, just the 4 squares. I thought my truck registered higher before, now it drops just below 1/2 when idling and is about 3/4 or more when I'm driving it . It seems to move along with how many rpm's I am running. I checked my oil level and its ok. What else could be the culprit? thanks
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
That's perfect oil pressure. Full scale is 60 psi, halfway is 30.
Just as if I knew what I was doin' |
"Ochre Ogre"
I was always told 10psi per 1000rpms is safe for a chevy engine. And the guage is 60psi like Duallie mentioned.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Mine pegs out high when at fast idle, but settles in at about the midpoint during normal idle. I used to be concerned that the pressure was too high, but whenever I've brought it up to others, I'm told there's nothing to worry about.
Paul 72 Cheyenne Super Custom Camper greenaz@hotmail.com |
If you take enough dashes apart there are truck dashes that have 80 lbs oil pressure gages also. I find those in the c40-c50 range often.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
thanks guys I guess I can rest easy now
