Old 10-21-2011, 09:17 AM   #1
dmcclanahan
Starter solenoid question
I'm putting in a push starter botton and I dont know what color the soleniod wire is. So what color is the wire (inside the cab) and what size is it?
dmcclanahan is offline   Reply With Quote
Old 10-21-2011, 09:46 AM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: Starter solenoid question
If you're putting a push button starter in, why not just run a new wire to your starter? That way you don't have to chase anything down. If you don't want to do that, then just trace the wire back from what's on the starter right now. And the wire should be about 12-14 ga.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 10-21-2011, 09:53 AM   #3
dmcclanahan
I traced it back to the fues box and then losed it from there (going into the cab).
Old 10-21-2011, 09:56 AM   #4
dmcclanahan
and the the solienoid wire has another wire spliced into it. Any idea on what that wire is or where it goes?
Old 10-21-2011, 01:51 PM   #5
dmcclanahan
I GOT IT.....it is the PPL/WHT wire that’s connected to the starter solenoid. You can find that wire connected to the starter switch at the base of the steering column.
