Old 10-21-2011, 12:09 PM   #1
72gmcshorty
72gmcshorty's Avatar
Should these holes be here?
Is there supposed to be a hole in the track where the window sits? There is a hole on both sides of the cab. Seems like a good idea to keep water from rotting the channel but at the same time it means water might drip into the tub...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-21-2011, 12:10 PM   #2
72gmcshorty
Re: Should these holes be here?
The hole between the 2 bolts...
1992 Gmc 2wd
Old 10-21-2011, 01:23 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Yes, they are there from the factory
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-21-2011, 04:09 PM   #4
Firebirdjones
Yes leave them there. They don't drip into the tub however.
If I remember right they just drip into the cowl which drains out of the bottom of the truck behind the fenders.
Important to keep it all clean from debri, or it will rust for sure.
Firebirdjones is offline   Reply With Quote
Old 10-23-2011, 02:44 PM   #5
71stroker
71stroker's Avatar
They are there from the factory so if the windshield gasket leaks your dash doesnt collect water. They do in fact drain inside the tub though.
If your truck is parked just right it will drip on the fuse box or emergency brake mechanism and also gets the dimmer switch wet.
1971 K10 1/2 ton short fleetside, 4 in. lift, sm465/np205, 383 waiting to go in.
1972 K10 short fleetside converted to 3/4 ton, 12 in. lift, t.350/np205, sbc 350.
1970 C10 short fleetside, saginaw 3 spd, no motor.
1971 GMC 3/4 ton 2wd suburban parts truck.(gutted)
1970 GMC 1/2 ton 4wd suburban t.350/np205 no motor parts truck.
71stroker is offline   Reply With Quote
Old 10-23-2011, 05:31 PM   #6
72gmcshorty
thats probably why my driver floor rusted away
1992 Gmc 2wd
Old 10-23-2011, 07:00 PM   #7
Firebirdjones
If that is indeed the case then that's the dumbest design I've heard of.
If GM were smart they could of at least had a nipple under the hole to connect a small drain hose and direct it to a less important place like,,,,,,OUTSIDE THE TRUCK
I've seen it on other cars, and this would seem to be a prime candidate.
