10-21-2011, 02:17 PM | #1 |
Senior Enthusiast
Grocery bag containment tip
Here’s a tip some may find helpful. I’ve never been very fond of taking the truck to the grocery store, loading everything in the back, and getting home to discover a jar of mayonnaise, jelly, or bottle of milk went flying across the bed. I’ve tried a variety of cargo restraints both when I had an open bed and a hard cover in place. Spider nets seemed too clumsy and straps or cargo nets never seemed to hold the items where they were convenient. Here’s a very simple method I stumbled upon to hold grocery bags right where I want them next to the tailgate.
Years ago I replaced every other fender bolt with a same size hardware store eyebolt. These required no holes to be drilled, and have proven immeasurably handy for tethering loads. Quite by accident I left a pair of long ball bungee cords in the eyebolt closest to the tailgate, on both sides of the bed. On the next trip to the store, it occurred to me to simply pass the bungee through the “handles” of the grocery bags and stretch the open end to the next eyebolt. It takes about 2 seconds to hook up or disconnect and holds everything in place in an upright position. If you actually use your truck and don’t mind having a couple of eyebolts installed, it’s a very simple alternative to cleaning up splattered contents from the bed. The photos aren’t very good, and the bed looks awful, but the pictures do tell the story. Here’s the passenger side of the bed showing the eyebolts: Here are the ball bungees I just leave hanging in the eyebolts: And here are grocery bags tethered to the bed wall. The bungees don’t show up real well being black against a black bed, but they stretch from the blue balls at the rear through the bag handles and loop over the forward eyebolt: |
10-21-2011, 02:31 PM | #2 |
Re: Grocery bag containment tip
Great Tip. Nothing worse than stuff sliding and rolling around back.
MusicMan70 1961 GMC Suburban |
10-21-2011, 03:00 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Do you work for Walmart? Just asking....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-21-2011, 03:04 PM | #4 |
Senior Enthusiast
10-21-2011, 03:12 PM | #5 |
Great tip!
Thanks for sharing.... |
10-21-2011, 03:22 PM | #6 |
...just another truck junkie..
I really like that idea with the eye bolts. I will have to remember that when I get to that point on my C20.
Mike "Bear" Shea |
10-21-2011, 03:56 PM | #7 |
It's Better With Nitro
Cool idea. I started using a Rubbermaid tub awhile back and then tying that secure since it has handles. The worst I had was a corn oil incident...that stuff was murder to clean up.
10-21-2011, 05:56 PM | #8 |
I run a bungie cord between the front most stake pockets (the hole in the bottom of the pocket) and loop the handles through that. I like the eye bolts.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
