Old 10-21-2011, 02:29 PM   #1
kikkegek
kikkegek's Avatar
Insulate the ceiling of your Burb?
hi guys,
I am putting a ceiling back in tomorrow in my Suburban.
what do you guys use for insulation of the ceiling of your Burbs?
for sound?
for heat?
for cold?
kikkegek is offline   Reply With Quote
Old 10-21-2011, 02:46 PM   #2
Mr. 250r
Mr. 250r's Avatar
Re: Insulate the ceiling of your Burb?
I don't think I've seen anyone do it myself I just put mine back in like it was you could try that sound deadening normally used on floor boards don't see why it wouldn't work but I don't see alot of sound coming from the roof as opposed to the floor
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-21-2011, 11:15 PM   #3
TheApocalyptican
TheApocalyptican's Avatar
I did some sound deadener on the big flat sections of the roof. Then I used a thermal insulation material over that which I completely covered the flat sections of the roof. All of it came from second skin. Big thing sound deadener could do on the roof is stop some vibrations on the big flat sections. Completely covering the metal is unnecessary. It is said that 25% coverage is all that is necessary. I probably am somewhere around said 25%. Main reason I did the work tho, was for the heat insulation. Definitely helped during the hot summer here.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 10-22-2011, 08:42 AM   #4
greguw
Body shops use to sell sheets of sound deading material ... it was like a stick sheet of tar paper ... You could just use Dyno matt floor insolation stuff .
greguw is offline   Reply With Quote
Old 10-22-2011, 04:55 PM   #5
kikkegek
kikkegek's Avatar
thanks guys!
