Old 10-21-2011, 03:43 PM   #1
airbrusher
longer brake lines needed
i have a 72 c10 w/disc brakes that i installed dropped spindles with 3 inch drop springs now my brake hoses are stretched to and past the limit, every one local has not a clue about longer hoses. is there something obvious that im missing here or does someone make extended hoses for this? john 3-16
airbrusher is offline   Reply With Quote
Old 10-21-2011, 03:53 PM   #2
vectorit
What?
vectorit's Avatar
Re: longer brake lines needed
Have you checked your local off road shops?
Or online with places like www.offroadwarehouse.com
Local shops may be able custom make them as well.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-21-2011, 04:16 PM   #3
airbrusher
never even thought of that will check it out thanks Blessings!!
Old 10-21-2011, 04:24 PM   #4
stomper
Junior Member
stomper's Avatar
My local NAPA dealer (old experienced parts guy) says he has a chart showing end fittings and lengths. Based on the stock hose, he can identify longer hoses that will fit. Also read in another post that '72 Monte Carlo fit and are 2" longer but have not confirmed.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 10-21-2011, 04:26 PM   #5
airbrusher
you are exactly right my napa guy just told me the same thing will check on the monte hoses thank you!!
Old 10-21-2011, 04:41 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
How long of hoses do you need? I bought the braided hoses from inlinetube and they fit just fine...and look pretty cool. I also have drop spindles, 2.5".
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-22-2011, 07:57 PM   #7
airbrusher
at least 2 inches longer mr napa says he can help me so guess we will see
