Old 04-16-2003, 04:51 AM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
GM Part #s
GM Vehicle Care Products:
1050002 Top Engine Cleaner $ 4.13
1052196 Lubriplate Lubricant $ 5.43
1052271 80w90 Axle Lubricant $ 5.42
1052358 Positraction Additive $ 5.34
1052367 EOS/Assembly Lube $ 5.34
1052627 Heat Valve Lubricant $ 5.77
12345104 Fuel System Trtmt. 20oz $14.03
12345347 Hydraulic Clutch Fluid $ 7.71
12345515 Fuel System Trtmt. 12oz $ 9.37
12345586 Cooling Sys. Fast Flush $ 3.78
12345837 Auto Trans. Conditioner $ 4.93
12345866 Power Stg. Fluid 16oz $ 6.81
12345867 Power Stg. Fluid 32oz $10.95
12346290 DexCool Antifreeze $11.69
12377916 Synchromesh Trans Fluid $ 8.32
12377967 DOT 3 Brake Fluid $ 4.97
12378508 Auto Trac Fluid $ 4.52
12378470 Dexron III/Mercon ATF $ 2.77
http://chevygear.home.attbi.com/Vcare.htm
I havent bought anything from this company, just thought someone would like the gm part #s
For some reason the link is adding something on the end of the address, it does work
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-16-2003, 05:52 AM   #2
Mike76251
Thanks for the try but that link is a 404.
It does look like good stuff on your list.
Mike76251 is offline   Reply With Quote
Old 04-16-2003, 06:25 AM   #3
MylilBowTie
Right turn Clyde
Delete the </a> it will work. Im not real sure how to type up html so I just used the buttons and one of them is messed up possibly?
Old 04-16-2003, 06:35 AM   #4
MSL
MSL's Avatar
Here you go i think it should work now.
MSL is offline   Reply With Quote
Old 04-16-2003, 06:53 AM   #5
Mike76251
Much better MSL....
Thanks to both of you!
Mike
Old 04-16-2003, 07:02 AM   #6
MSL
MSL's Avatar
No problem glad to help out.
