I was wondering if anyone makes a full size insert in anything other then cardboard? I have the Vintage Air plastic one in my 67, came with my a.c. kit. I have the room for a full size insert in my `70 panel and would like something stronger then original. Any ideas?
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
Re: Looking for a better glove box insert?
I've wondered about painting the cardboard or coating it with resin for fiberglass, but got lazy.
Kinda lazy myself, but not bad ideas...
![]() Join Date: Jul 2010
How about painting tha cardboard linner with bed liner in tha spray can..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
actually i can try that, ill use my old one to see how it works out.
its all about the +6 inches
I took the cardboard (soggy) glovebox out of mine, traced it out on some thin sheet metal, cut it out, bent it up and installed it.
![]() Join Date: Sep 2010
Sounds interesting, I`d love to see one.
I got a plastic one from a company called Old Air Customs. A lot sturdier.
Man of Mini-Talents
I wonder how you go about installing a sturdier one. You a about have to fold it in two to get it in there.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#11 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I had an old cardboard one in my IH Scout2 and I used the spray on bed liner in a can, and it's kept everything nice and dry, and has held up well for 10ish years. Still looks great too.
Posted via Mobile Device |
#13 |
Here's a link to this one that was ALMOST made ( four years ago !!! ) It looks like it might have been flexible enough to install it. http://67-72chevytrucks.com/vboard/s...d.php?t=243232 . . . . |
#14 |
I made mine out of aluminum heres the pics I just took my old cardboard one apart and used it as a template.
![]() ![]() And finally installed ![]()
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
#15 |
Old member
I could do something like that. How does it install though. Can you install it through the door opening?
#16 |
Very interesting, subscribing...
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
#17 |
Yeah the aluminum that I used is extremely flexible and it bends enough to fit through the door opening. It is extremely flexible but sturdy. I just used rivets to hold mine together. Plus it can be removed easy to, I had to take mine out when I swapped cabs.
#18 |
lot of great ideas so far.
#19 | |
Old member
![]() Quote:
Cool thanks for sharing this. I will look into it tomorrow at Lowes for sure. ![]() ![]()
#20 | |
This stuff http://www.lowes.com/pd_12540-205-66...ing&facetInfo=
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 Last edited by mas09ts; 10-22-2011 at 08:48 PM. |
#21 |
mine looks just like that. I didnt use rivits though, small nuts and bolts. I didn't put the nuts and bolts on till it was in place. By doing that, I was able to squeeze the top and bottom closer together enough to fit it sideways though the door opening..
I placed a thin rubber mat on the floor of the box though to keep junk from rattling around in there. |
