Old 10-22-2011, 09:05 AM   #1
summerj
Need Tire Advice for 700R 4 and 307 Gears
Hello All
I am finishing up the transmission install in my 65 short bed fleetside. Had a 700R 4 Built with 3rd and 4th gear ceramic clutch upgrade. Also stalled a 5 lug '72 rearend with 307 gears. An early 80's 350 CI chevy with headers mild cam and 750 Holley is my power plant. I will be pulling a 2200 lb catering trailer around town (with electric brakes) but not at hwy speeds. Trailer tung has about 250lbs of tung weight (frame Hitch installed)
Question: What size tires should I run with this gear/motor/ transmission combination? I want the stance of the truck to be semi low -so low profiles would be preferred. Also have the 2" drop spindles on front. Rims are 16"
Any Tire Size or Manufacturer Recommendations? Gotta purchase tires soon.
summerj is offline   Reply With Quote
Old 10-22-2011, 11:10 AM   #2
Indian113
Indian113's Avatar
Re: Need Tire Advice for 700R 4 and 307 Gears
I would think towing with 3:07 gears and a 700R4 your not going to get into 4th gear. I have 3:73's and they work great with a 700R4. You will need to have a short tire to raise your gear ratio a tall tire will just give a even lower ratio.
Indian113 is offline   Reply With Quote
Old 10-22-2011, 12:16 PM   #3
Mechanic77
16's?.....I'd recommend a P225/60R16.....roughly 26.5" tall and a very popular size in the late 90's and early 00's so they are easy to find and cheap, too Fits perfect on a 16x7 rim
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 10-22-2011, 01:29 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
From the factory, 700's were set up with 3:73 or 4:10's. I have the same combo as you in my 'burb and I went to a 295/50/15 to get 'more gear' out of the too low combo. I was turning about 1700 rpm @ 70mph with a 275/45/20.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
