454 MAKES IT ROAR
Wheel Bearings...front & rear.
OK fed up searching, could someone please tell me what part #'s I need? I want to replace the wheel bearings on my truck...front & rear, it's a 71 1/2 ton rwd.
There's two in the front wheels (inner & outer) & one in the rear..right? and is it just bearings I need or are there any seals to buy also?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
![]() Join Date: Nov 2007
Re: Wheel Bearings...front & rear.
I hope this helps... I searched for a 71 Chevy half ton...
http://m.napaonline.com/parts/PartsL...Ntk%3dCategory http://m.napaonline.com/parts/PartsL...Ntk%3dCategory http://m.napaonline.com/parts/PartsL...Ntk%3dCategory http://m.napaonline.com/parts/PartsL...Ntk%3dCategory
72 C20 Longbed 05 1500 Z71 |
#3 | |
454 MAKES IT ROAR
To add insult to injury, when I click on a few of the listings in the hope of finding out more, it comes up with nothing listed for that item, even worse when I clicked on the "wheel bearing cup inner" it tells you it's for a "Transfer Case Idler Shaft"...is that something that's found on a rear wheel? am I getting stupider with age or is this more complicated than it needs to be?? The trouble is I have no idea how many component parts are in a wheel to make it spin, that is my first hurdle, so basically if knew there was one wheel bearing per corner I would want to be able to go and order two front two & rear, and if I knew there is like umpteen different pieces per corner, i.e seals, inner bearings, outer bearings & cups, then I want to be able to order a full set front and a full set rear..
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 10-23-2011 at 06:39 AM. |
Has more rust than truck...
The plain ring or cup is know as the race. Races are only used in the front tapered roller bearings. So to do all of the wheel bearings you'll need.
2- front seals 2- Inner front bearings 2- inner front races 2- outer front bearings 2- outer front races 2- rear seals 2- rear wheel bearings. |
#5 | |
454 MAKES IT ROAR
thing is if I had realised there were so many component parts especially in the fronts I would have worded my original post differently. Cheers again mate, your list has demystified this whole thing for me and it will for others like me.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 10-23-2011 at 01:47 PM. |
454 MAKES IT ROAR
OK, these are the part #'s for the list of parts that usmc kindly did for me, could you guys have a look and see if they look correct?
All for 71 C10..... Front wheel seal http://www.napaonline.com/Catalog/Ca...984_0068541769 Front inner bearing (with race): http://www.napaonline.com/Catalog/Ca...BR5_0338835852 Front outer bearing (with race): http://www.napaonline.com/Catalog/Ca...BR3_0073771228 Rear wheel seal (gm axle): http://www.napaonline.com/Catalog/Ca...044_0075388686 Rear wheel baring: http://www.napaonline.com/Catalog/Ca...9TV_0329294944
