10-22-2011, 07:31 PM | #1 |
'71 Blazer headlight pull removal
I'm sure this is a simple thing, but I can't figure it out and need some guidance from you all. How do you remove the headlight pull from the gauge bezel on a '71 K5? I got the nut off, but can't get the rod detached from the unit inside the dash.
10-22-2011, 07:53 PM | #2 |
Re: '71 Blazer headlight pull removal
reach under dash, on top of headlight switch is a small button, push down and pull out the light switch
10-22-2011, 07:54 PM | #3 |
You should pull the wiring harness off the switch first, or your headlights will stay on.
10-22-2011, 09:50 PM | #4 |
That was about the easiest thing ever…
Thanks man. Is there a good manual to learn this kind of stuff? I have the Haynes manual but it's for '67-80something models, so not exactly specific. I really appreciate your help. |
10-22-2011, 10:00 PM | #5 |
Do you know how to get the stock radio out? Stuck on that too.
10-24-2011, 12:20 AM | #6 |
through the glove box.
10-24-2011, 06:44 AM | #7 |
Pull the knobs and you will see nuts, may be a strap that at the back of the radio
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
