Old 10-23-2011, 08:06 AM   #1
jasonroman
jasonroman's Avatar
question about wheels and tires....storage.
not sure if its right place to post.
i have 2 trucks. gonna make one out of 2. both trucks have ralleys and both sets have new tires.
my old truck with bad trans was dropped 5/7. smaller offset tires.
new truck has no drop....YET... anyway, the wheels on the new truck are huge. stock truck, big rubber.
im not sure if im gonna drop truck now, or after winter....new jersey....
anyway, question is, how to i store my wheels and tires?
spent 500 on tires, so i dont want them to go bad sitting.
sorry if its a dumb question.
can i just put them in the basement, stacked up. and when i decide to drop truck, swap em on?
jasonroman is offline   Reply With Quote
Old 10-23-2011, 12:55 PM   #2
tasian
tasian's Avatar
Re: question about wheels and tires....storage.
yeah they should be fine i think the main thing is you want them out of the sun i'd clean them before you let them sit too
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 10-23-2011, 01:52 PM   #3
jasonroman
jasonroman's Avatar
ok. thanks
will do that.
just didnt want to put em in the basement and end up with bad tires in a couple mnths
Old 10-23-2011, 06:57 PM   #4
MADMIKE
Although, keeping them out of the sun is a good idea, you will also need to keep them in a room with a steady temperature. If placed in an area or room that fluctuates with heat, the tires can become heat cycled. In doing so the tires will become harder, losing their ability to grip the road.
Originally Posted by Tire Rack
• Don't store a vehicle with weight on its tires for extended periods of time. Long-term inactivity is more harmful to tires than weekly drives that flex the tires and help maintain oil dispersion within the rubber compounds.
• Keep the tires out of direct sunlight whenever possible. The sun's ultraviolet rays and radiant heat are detrimental to rubber. We have used a pyrometer to measure tires that were simply sitting in direct sunlight on a parked vehicle. Surprisingly those tires' temperatures measured 135° Fahrenheit on their surface.
• Before storing, use a tire brush to clean each tire with soap and water to remove brake dust, dirt and grime. If the tires are still mounted on wheels, use a wheel brush to clean the wheels with an approved cleaner as well. Dry with a towel and let any remaining moisture thoroughly evaporate.
DO NOT APPLY ANY TIRE DRESSINGS. Tire compounds are formulated to resist ozone cracking or weather checking.
• Place each clean and dry tire in its own large, opaque, airtight plastic bag (such as lawn and garden bags) for storing. Avoid allowing any moisture to remain and remove as much air as practical (some drivers even use a vacuum cleaner to draw out as much as possible). Close the bag tightly and tape it shut. This places the tire in its own personal mini-atmosphere to help reduce oil evaporation.
• While Seasonal Tire Totes make it neater to store tires, easier to carry tires and reduce the possibility of depositing brake dust, dirt and grime in the trunk or on the back seat during transportation, Seasonal Tire Totes are not airtight nor designed to prevent exposure to the atmosphere. The recommended solution would be to place each clean tire and wheel into the airtight plastic bag and then cover the sealed bag with a Tire Tote.
• If you choose not to store white letter/white stripe tires in plastic bags, it is important they be stored or stacked white-to-white and black-to-black to prevent staining the white rubber. The black rubber used on the tires' white letter/white stripe side is compounded differently then the black rubber used on the opposite side. A layer of non-staining black rubber covers the white rubber on the tire's white side to prevent oils in the tire from migrating into the exposed white rubber and discoloring it, however the black sidewall uses standard rubber. Stacking all tires white sidewall up will allow the oils from each tire's black sidewall to migrate into the white rubber of the tire below it.
• Place the tires in a cool, dry location. It is better to store tires in a dry basement or climate-controlled workshop than in a standard garage, storage shed, hot attic or outdoors. While basement and shop surroundings tend to remain cool and dry, conditions found in typical garage, shed, attic and outdoor locations often include a wide range of hot and cold temperatures, as well as seasonal precipitation and humidity.
• Keep the tires away from sources of ozone. Electric motors that use contact brushes generate ozone. Keep your tires away from the furnace, sump pump, etc.
-Michael
MADMIKE is offline   Reply With Quote
Old 10-23-2011, 08:59 PM   #5
jasonroman
jasonroman's Avatar
thanks for the info and tire rack info.
i appreciate the help.
i have the toats, maybe ill bag em up and then put them in toats,
thanks again for help guys
