Old 10-23-2011, 02:03 PM   #1
Project77
Need wheel help
i need help choosing the correct backspacing for the rims i want as much negative backspacing as possible without causing any serious issues
also need help with choosing the correct bolt pattern
Project77 is offline   Reply With Quote
Old 10-23-2011, 02:28 PM   #2
J Knight
J Knight's Avatar
Re: Need wheel help
On the rear a 5.5in backspace on a 10in wide rim puts the wheel almost dead center. Not sure about the front but I've read that 20x8 with 5.25in backspace is perfect.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-23-2011, 02:30 PM   #3
Project77
Re: Need wheel help
could you teach me about backspacing what it means and what it does because i have no idea what it is talking about
Old 10-23-2011, 02:34 PM   #4
J Knight
J Knight's Avatar
Re: Need wheel help
Back space is the distance from the mounting surface of the rim to the outetmost lip of the backside of the rim. Does that make sence?
John
Old 10-23-2011, 02:36 PM   #5
Project77
Re: Need wheel help
yea kind of the more backspacing the deeper the rim?
Old 10-23-2011, 02:41 PM   #6
78 Chevyrado
Re: Need wheel help
Here's a Backspacing diagram. the face of the wheel is to the LEFT.
Here's a Wheel Offset Diagram. the face of the wheel is to the RIGHT.
78 Chevyrado is offline   Reply With Quote
Old 10-23-2011, 02:44 PM   #7
J Knight
J Knight's Avatar
Re: Need wheel help
Not exactly. Example; A 10in wide rim with 5.5in of backspace has 5.5in of rim on the backside and 4.5in of rim on the frontside.
John
Old 10-23-2011, 02:47 PM   #8
Project77
Re: Need wheel help
okay from what i see in the diagram the smaller the backspacing the deeper the rim and a negative backspacing is a deeper rim? right?
Old 10-23-2011, 02:51 PM   #9
J Knight
J Knight's Avatar
Re: Need wheel help
I'm guessing your truck is 77c10 right? What wheel and tire set up do you want and is it lowered or not?
John
Old 10-23-2011, 02:55 PM   #10
Project77
Re: Need wheel help
i dont know what the backspacing is on my rims i will go out and check that and no its not lowered but i am going to lower the rear end 2 inches and leave the front stock height just to get it level i currently have 15s but i want to change to 18s
Old 10-23-2011, 03:02 PM   #11
J Knight
J Knight's Avatar
Re: Need wheel help
From what I've been hearing 18s are getting hard to find wide enough tires for, but I could be wrong.
John
Old 10-23-2011, 03:05 PM   #12
Project77
Re: Need wheel help
okay the backspacing on my current rims is 3 1/2 inches and front spacing is 6 inches they are 15s sitting on 31x10.50r15lt standard rim 81/2j what ever all that means
Old 10-23-2011, 03:10 PM   #13
J Knight
J Knight's Avatar
Re: Need wheel help
You have 15x10s with 3.5in backspace.
John
Old 10-23-2011, 03:12 PM   #14
Project77
Re: Need wheel help
my truck
the rims i want backspacing and all that isnt correct yet just the rim style
http://www.summitracing.com/parts/MBW-61325/
Old 10-23-2011, 03:13 PM   #15
Project77
Re: Need wheel help
i never thought those rims were 10in wow thats awesome thats alot of rim under that tire haha
