Old 10-23-2011, 06:48 PM   #1
darkone
I made a mess (flushing my pwr steering) how do i get the ATF out?
hey all, i read you can use ATF to flush your pwr steering. so i did. unfortunately theres ATF in the cylinder still (of the actual PWR steering unit). this is besides the fact that ive managed to spray most of my driveway with ATF. anyway, how do i get the rest of that shiz outta my pwr steering unit?
darkone is offline   Reply With Quote
Old 10-23-2011, 07:09 PM   #2
hayhauler71
hayhauler71's Avatar
Re: I made a mess (flushing my pwr steering) how do i get the ATF out?
Take the return line off the pump and cap off the port on the pump
Put the return line in a drain pan or suitable container
Have a buddy start up the truck and turn the steering lock to lock as you add fluid to the reservoir [make sure you do not let the pump run dry]
This will flush out the whole system
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-23-2011, 08:28 PM   #3
It won't hurt it. It's actually a good little trick to run ATF in one that leaks.
Old 10-23-2011, 08:41 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the owners manual calls for dextron
Old 10-23-2011, 09:01 PM   #5
PHAT TONY
PHAT TONY's Avatar
I've ran transfluid in my p/s for years; even in my '98!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-23-2011, 11:20 PM   #6
pritch
pritch's Avatar
I had one that leaked so bad, I put used motor oil in it. It worked fine for months until I got a new one.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 10-23-2011, 11:47 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Auto transmission fluid is basically a hydraulic fluid. Power steering pump and gear box are hyraulically operated parts so it won't hurt it. If it's a big concern for you just remove as much as you can and refill with power steering fluid.
I wouldn't lose sleep over it as others have said. I've used it in my power steering before.
68gmsee is offline   Reply With Quote
Old 10-24-2011, 07:41 AM   #8
MARKDTN
X2 (or 3)
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
