Wiring Harness Question
Ok. First of all i left my camera at the inlaws house.....NO PICS...
But I will ask the question anyways I'm working on a 69 CST that was originally a BB truck. First Question. On the wiring harness in the engine bay right beside the drivers head light plug are two tan wires crimped together. Does this go to the horn? Second question. On the drivers side also close to the headlight plug is a green wire. It is around 14" long. Does it go to the Wiper washer pump? Third Question. Also close to the Drivers side headlight plug is a male plug that has four wires going into it. They are..Blue, white, red and brown. Where the heck does this go to? And what does it power? Sorry I dont have any Pics. I'm sure it would make it much easier to answer. |
![]() Join Date: Apr 2008
Re: Wiring Harness Question
#1 The only tan wires on mine are for the head lights
#2 green wire is for the horn, wiper washer pump is under the dash. #3 plug is probably for the voltage regulator. A lot of guys leave the reg in place after they install an internally regulated alternator
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Although if the reg is not there near the drivers head light maybe you already have an internally regulated alt and the voltage regulator plug has not been removed
#4 | |
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze |
Thanks!That is exactly what I needed.Mine is the same.
