Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-23-2011, 09:57 PM   #1
IOWNATRUCK
Speaker Wiring Help!
Ive got a few questions about installing an after market stereo/speakers possibly. In my 1984 C10 Stepside, there are two speakers behind the bench seat, idk if theyre stock or aftermarket but they certainly need to be replaced. but the only wire that runs into them is a small black wire. To install new speakers would i need to start all over or is it possible to just find some home speakers, anything that just uses one black wire into the speaker so i can use the wiring and ground thats already been done? Any suggestions ideas help etc is appreciated, im a newbie with wiring, i know i know.
Thanks.
IOWNATRUCK is offline   Reply With Quote
Old 10-24-2011, 04:06 PM   #2
jimmydean
jimmydean's Avatar
Re: Speaker Wiring Help!
I would run new wires. If you aren't running anything special, but want to run some good wire, pick up a spool of 16awg from Radio Shack. I have used it for a lot of low power speakers and it works great.
http://www.radioshack.com/product/in...ductId=2102569
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-24-2011, 07:05 PM   #3
76stepsidechevy
Even the stock speakers used two wires per speaker, its possible your seeing another wire or somebody cobbled in speakers and grounded the negative to the chassis. are there plates in the cab corners with 4x10s? If so i'd take a second look.
76stepsidechevy is offline   Reply With Quote
