Old 10-23-2011, 10:47 PM   #1
IOWNATRUCK
Engine questions.
I have a few questions and concerns about my truck, for some backround info, the engine is less than 2000 miles and new, along with the trans. When my truck is in drive, there is a faint high pitched noise, nothing that others would hear, just something im obsessing about, the noise is non existent when the truck is in park, but starts whenever its in drive just idling. is this something i should be concerned about? any ideas? I checked the belt, and i dont believe thats where its coming from. Also, when the truck is in park, the idle is alot higher than in drive, is this normal?
Thanks.
IOWNATRUCK is offline   Reply With Quote
Old 10-23-2011, 11:59 PM   #2
85Bowtie
85Bowtie's Avatar
Re: Engine questions.
What do you consider significantly higher idle? Of course the idle is going to be higher in Park than in Drive.
You just have to trace the noise down yourself. Does it sound internal? A rattle? A whine? What is it?
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 10-24-2011, 12:05 AM   #3
IOWNATRUCK
Yeah, im thinking the idle isnt a concern as it was only occuring during warm up until i hit the gas, but yes its just a high pitched noise thats very faint only when in drive, not coming from the engine bay, it sounds as if its coming from the middle of the undercarriage, thanks for the response and help man.
Old 10-24-2011, 12:14 AM   #4
85Bowtie
85Bowtie's Avatar
May want to check your inspection plate to see if it's loose or not, or pull it and check to make sure the converter bolts are tight...
Old 10-24-2011, 12:21 AM   #5
IOWNATRUCK
Okay, thanks for the help il be sure to try. Would loose bolts make a high pitched sound? its not a knocking noise or anything just a really faint high pitched ringing only in drive. Theres no loss of power or anything so im pretty sure the converter is good, and snug.
Old 10-24-2011, 12:28 AM   #6
379redneck
379redneck's Avatar
Are you sure its not your fuel pump that your hearing?
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 10-24-2011, 12:32 AM   #7
85Bowtie
85Bowtie's Avatar
I don't know. I'm trying to think of what could be making that sound. If they're "slightly" loose you may get more "constant" contact between the different surfaces that may make a more uniform sound VS. a banging sound or something similar. Maybe the higher RPMS help stabilize whatever may be loose. I'm not exactly sure, I would have to hear it to know for sure.
If it's a carb'ed truck than he most likely doesn't have an electric fuel pump.
Old 10-24-2011, 12:33 AM   #8
IOWNATRUCK
I havent even looked into that, that slipped my mind, thanks i will, but wouldnt that make the sound in all gears as long as the trucks running? My truck is making the sound only in drive for some reason.
Old 10-24-2011, 12:34 AM   #9
IOWNATRUCK
yeah its carb, and thanks for all your help guys.
Old 10-24-2011, 12:34 AM   #10
85Bowtie
85Bowtie's Avatar
The reason I mentioned that is because you said the engine and trans were basically new....meaning they have been "touched"....so that would be a good place to start I would think.
Old 10-24-2011, 12:36 AM   #11
85Bowtie
85Bowtie's Avatar
If it's in drive....it is in "all gears" from an RPM standpoint. So yes, in any "gear" other than drive or neutral where you will have a higher idle, you will have a "rougher" running engine which can sometimes help exagerate things that are slightly loose.
Old 10-24-2011, 12:37 AM   #12
IOWNATRUCK
yeah thats true, thanks for all your help, and btw, thats a killer list of cars, got a 69 plymouth satellite myself.
Old 10-24-2011, 12:40 AM   #13
379redneck
379redneck's Avatar
Forgot about that
Old 10-24-2011, 12:46 AM   #14
IOWNATRUCK
thanks for the help too 379
