10-23-2011, 11:07 PM | #1 |
body mount bushings panel/ burbs
does anyone know who carries a kit for burbs and panels? I tryied classic parts did not see them.
10-23-2011, 11:38 PM | #2 |
Resistance is Futile
Re: body mount bushings panel/ burbs
I mite be wrong, but I believe that people are using 67-72 kits. I know for sure that the weatherstrip kits for 67-72 work for our stuff. Hopefully someone will chime in as I believe this topic has been discussed before.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
10-23-2011, 11:59 PM | #3 |
that would work for me. I'll check my father inlaws burb tommarrow. the rubber is just some 3/4" thick rectangles. cab mounts look the same as 73-87 pickup. core support is obviously no big deal. I would like a do all kit though.
10-24-2011, 01:21 AM | #4 |
there are no kits. I will find the link for the insulators later
ron |
10-24-2011, 01:23 AM | #5 |
10-24-2011, 07:08 AM | #6 |
I believe I used 2 sets for a regular pickup and that worked for my 62 Panel. Its been almost 20 years so I am not to clear about weather it took a few shims to get it strait.
10-24-2011, 09:06 PM | #7 |
Thanks for the link Padresag. That is them. But $14 ea. x 8 is a little steep and they only show half of one in the pic so that could be 16. therefore I just ran out and put all the used ones together from two trucks and found enough to make one usable set. that will leave me cab and core support bushings. which I have to replaced they are toast. I found them on lmc with the bolt I think.
