Old 10-24-2011, 01:24 AM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
braided brake hose help
On my 1980 c-10 I'm doing a rear disc brake conversion with captain fab brackets, astro van rotors, factory style brake lines and wilwood d-52 calipers. I do know that the calipers use a 7/16 banjo bolt instead of the original 10mm, would the braided hoses that fit a mid 70s truck for the front work with the standard bolt size or would the hose be to short, also for the rear brake hose to the caliper about how long should it be.
Thanks Aaron
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-24-2011, 06:47 PM   #2
flamingbig10
6.0 powered square
Re: braided brake hose help
anyone
Aaron
Old 10-24-2011, 09:28 PM   #3
flamingbig10
6.0 powered square
I"ll guess I"ll go with braided replacement kit for the front and for the rear brakes 3/16 Brake Line to 7/16 Banjo 12" long
Aaron
Old 10-24-2011, 10:25 PM   #4
mbgmike
Maybe ask CaptainFab? he makes the brackets. Any Brakequip dealer can make your lines. its what they do
mbgmike is offline   Reply With Quote
Old 12-29-2011, 08:48 PM   #5
SoCal Wreckage
In case you haven't figure this out yet. You can call Crown Performance and have some custom SS brake lines made. www.crownperformance.com 760-599-0090. They will ship.
SoCal Wreckage is offline   Reply With Quote
