Old 10-24-2011, 02:34 AM   #1
maromero1973
Lightbulb Possible dumb question
Ok so I've got a 73 c-10 3 on the column, it's got disc brakes but id like to add power disc.... do I just bolt on a booster? Id also like to convert to auto on the column, I was thinkin about finding a donor and swap everything over.... what's my choices on candidates for a one stop shop? It's gonna be a cruiser and 3 on the column .... well when it gets bad its just a pia
maromero1973 is offline   Reply With Quote
Old 10-24-2011, 07:38 AM   #2
john_p
Re: Possible dumb question
my 73 has a factory booster behind the master.. everything else looks standard.. btw auto is not 3 on the column.. the old 3 on the tree is what we have now.. major old school
john_p is offline   Reply With Quote
Old 10-24-2011, 10:46 AM   #3
walkerb
walkerb's Avatar
My 74 was a 3 on the tree and the po moved it to the floor.
The power brake thing, you need a power brake pedal assembly and a booster from a power brake truck.
I would find a complete donor truck with the stuff you need.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-24-2011, 12:13 PM   #4
maromero1973
I know I will need radiator,trans cooler lines, brake booster/master cyl..... inside I will need an automatic steering column, the entire brake pedal assembly ...... I guess I need to be specific when I ask a question here....... does it really matter what year donor I should shop for.... would a sub be out of the question as far as donors? As far as bolt on goes.... what am I limited to.....? Thanks y'all
Old 10-24-2011, 12:16 PM   #5
maromero1973
@John P....... I know what 3 on the tree is, but I thought the ferd guys coined that one.... 3 on the column means there's a clutch pedal down there.....
