Old 04-16-2003, 01:46 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Master Cylinder Question
I bled the brakes last night and noticed that when depressing the brake pedal the fron bowl is pushing up fluid kind of like a fountain. I still have a soft pedal but it will stop. What could be causing the fluid to do this?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 04-16-2003, 05:58 PM   #2
Gordo
Smile
The fountain is normal, check your rear brake adjustment. Unless your gravity bleeding the system, keep the cap on the master when you pump the peddle.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-16-2003, 06:33 PM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Air trapped in the lines would be my guess. As you compress the hydraulic fluid in the lines by applying brake pressure, you squeeze the tiny air bubbles in the line. That could cause a "squishy" pedal. Bleed the system a ltlle more, and that should cure the "squishies"
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
