Old 10-24-2011, 03:22 PM   #1
michael bustamante
michael bustamante's Avatar
another seat idea to ponder
So I have a set of buckets and the center console / middle seat from an '03 silverado. have any of you ever put these in your blazer? were you able to still use the tilt foward frame? any pics? how about the back bench? I have that also. have any of you found a way to mount that to the tilt foward frame?
1967custom
michael bustamante is offline   Reply With Quote
Old 10-27-2011, 03:44 PM   #2
michael bustamante
Re: another seat idea to ponder
anybody?
1967custom
Old 10-27-2011, 04:47 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
tvblazer did in his 78, he's got a build thread here somewhere.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-28-2011, 08:40 AM   #4
str8axle55
I don`t know about the rear bench from a truck, but the Suburban 3rd row is the same width as the stock blazer seat. If you swapped all the loor brackets, you could have a folding removable rear. I know you can do the front seat using the stock Silverado mounts, without to much trouble. I don`t know if the cntr console will work though. My buddy put 02 seats in his K5, but used the split bench w/out the cntr seat, and it was almost a bolt in. I really don`t think you will be able to use the stock K5 brackets in any way.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 10-28-2011, 11:41 AM   #5
Mr. 250r
Mr. 250r's Avatar
For the front buckets from newer trucks I think most people notch the floor pan out for the rails since they are taller I guess and then put a reinforcing piece under the body because the seat belt is in the seat ad no longer on the wall as for the backs I'm not sure
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-28-2011, 01:37 PM   #6
michael bustamante
I was actually trying to think of a way to use the stock seat mounts to keep the tilt on the passenger seat. I think Ill have to start from scratch. Ill keep you guys posted
1967custom
Old 10-30-2011, 07:22 PM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
I put 02 silverado front buckets in my 75 K5 a few years ago. Because the silverado seat frame/tracks are all integrated, you can't keep the pass side tilt forward function for access to the rear seat. However, the seats move far enough forward that tilting the seat back gets enough room to get back there. I made brackets to bolt to the existing seat mounting points on the floor and match up to the silverado frames.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 10-30-2011, 08:46 PM   #8
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I've been thinking about putting a set in the front of my Suburban out of an 04 silverado myself
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-03-2011, 08:32 AM   #9
iceship
Has anyone converted bench seat brackets to fit buckets.. just trying. Not to do a lot of cut and paste... Lol
iceship is offline   Reply With Quote
