Old 10-24-2011, 06:51 PM   #1
porter90
porter90's Avatar
dare to be different engine choices?
hopefully i dont get shunned for this, but anyone on here used an engine other than chevy in their trucks, or know someone that has? my dad had a gto when i was growing up and i have a 350 or 400 pontiac lined up to go in the 64. anyone know of people dropping poncho power into an ol chev or gmc?
porter90 is offline   Reply With Quote
Old 10-24-2011, 07:00 PM   #2
Northern lights
Re: dare to be different engine choices?
I bought a '60 short step for parts years ago that had a 350 pontiac in it. A nailhead would be cool.
Northern lights is offline   Reply With Quote
Old 10-24-2011, 07:12 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=487813
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-24-2011, 07:38 PM   #4
porter90
porter90's Avatar
nailheads are AWESOME! how did that truck go with the 350?
Old 10-24-2011, 08:55 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Yep, I run a 462 ci Pontiac in my C-10.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-24-2011, 08:55 PM   #6
Wolfinthesnow
Wolfinthesnow's Avatar
Nailheads FTW!!! I have pics of mine in the link above. Got it back from the machine shop thursday. Picking up another 401 naily saturday. Approx 60,000 miles on the engine, complete except intake and rockers. $100
I dont care how you did it in California!!!
Wolfinthesnow is offline   Reply With Quote
Old 10-24-2011, 09:36 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
put a 75 455 and a th350 out of a 79 ta in my 63 long step dropped right in!
used the shorter 3 speed on the column driveshaft,and also used a set of motor mount towers out of a 73-87 3/4 ton 2wd, -direct bolt up to both-.
pirated the transmission crossmember out of the 79 ta, 2 bolt holes lined up, and had to drill 2.
had to remove the e brake crossmember for clearance, and haven't figured out what I will do there yet... thinking of seeing if the 66 style e brake system will work.
cut the original bellhousing mounts off the frame.
had an exhaust shop bend some 1.5 inch tube for the upper radiator hose, and had to trim the stock aircleaner to fit around the deluxe heater...
used a stock auto column out of a 63 gmc, might have been a hydromatic? regardless it had the correct detent for the th 350, used the linkage from the 73- 87 auto, including the bellcrank(?) and its mount that is bolted to the 73-87 frame.
if I can I will get some pics of the install soon.
used the stock pont. exhaust manifolds and cross over pipe for now, but dual exhaust doesn't seem like it would be a problem.
Old 10-25-2011, 12:12 AM   #8
blackedoutharley
Kaufman heads?
Nice down tube, got any more pics of your truck?
blackedoutharley is offline   Reply With Quote
Old 10-25-2011, 08:55 AM   #9
porter90
porter90's Avatar
nailhead for 100?! thats crazy! vin that motor is just beautiful! i bet that thing cranks, id love to see the rest of the truck. and jonz pics of tht install would be primo! this is great, im glad im not the only one that wants to do this
Old 10-25-2011, 09:01 AM   #10
vin63
vin63's Avatar
Yes, sir...running KRE D-Ports on the truck, and the High-Ports on the Funny Car. Here's a link to my introduction thread when I tore the truck down again: http://67-72chevytrucks.com/vboard/s...d.php?t=288712
Here are a couple more photos of the engine, in case anyone else is interested in running a Pontiac...
This is the dyno sheet on this interation of the engine on 91 octane:
Old 10-25-2011, 09:25 AM   #11
Rich 5150 69
Vin are you using stock truck engine mounts or custom units..?
Old 10-25-2011, 09:39 AM   #12
chevyrestoguy
chevyrestoguy's Avatar
I have always thought that a Pontiac engine is a perfect swap candidate for the old GMC engines. The Poncho engines are torquey and make excellent truck engines. I like Pontiacs a lot.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-25-2011, 11:35 AM   #13
vin63
vin63's Avatar
I fabricated my own frame to block mounts from scrap tubing and plate I had laying around, but you can use the regular frame mounts and the GM conversion block mounts.
Old 10-25-2011, 05:22 PM   #14
darkhorse970
darkhorse970's Avatar
How about a 409!!
http://www.remarkablecars.com/main/c...let-00153.html
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 10-25-2011, 09:26 PM   #15
joedoh
joedoh's Avatar
I have a s10 2.2 4 cylinder in my 65. yeah I know it wont win any stoplight races but its pretty close to the stock hp and tq and I dont have little man syndrome anyway. just kidding. It drives just fine though, plenty of pep.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-26-2011, 10:26 AM   #16
vin63
vin63's Avatar
A buddy of mine is building a pretty radical Ecotec for his '57.
Old 10-26-2011, 11:37 PM   #17
Northern lights
Don't know, I towed it home and parted it out.
Old 10-27-2011, 09:44 AM   #18
Bowed
I was curious what kind of gas mileage you get with the 4 cyl . What are your gears ?
Bowed is offline   Reply With Quote
Old 10-27-2011, 10:15 AM   #19
bo-w
no replacement for displacement , I'm looking to slowly stockpile parts and cash for a big block
bo-w is offline   Reply With Quote
Old 10-27-2011, 10:21 AM   #20
Rich 5150 69
Same here bo-w, generation 4 block....
Old 10-27-2011, 01:10 PM   #21
joedoh
joedoh's Avatar
Stock 98 s10 drivetrain, so I think a .7 overdrive and 3.73 rear. I haven't run a full tank through it yet, had it together with the 62 body and changed to a BBW 65 cab. But the sum is lighter than the s10 and the c10 so it should better the 25 predicted by the s10, depending on the aero effects.
Old 10-27-2011, 08:30 PM   #22
Bowed
That's interesting and I hope it meets your expectations .
Old 10-28-2011, 09:25 AM   #23
awbrown
I guess my next different swap will be a 250 with a turbo , i got the manifold yesterday and the turbo about 3 months ago ....
awbrown is offline   Reply With Quote
Old 10-28-2011, 09:30 AM   #24
Warrens69GMC
Warrens69GMC's Avatar
I always wanted to see a early Chrysler Hemi in one of these trucks
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-02-2011, 06:32 PM   #25
porter90
porter90's Avatar
its funny you mention that! i just got a line on an old 392 xD haha that would be sweet! awbrown, where do you find info on stuff like that? i cant picture how the turbo would go on a 250...what kind of rpms would you be running with a turbo? must have to be a small-ish turbo to get full spool with the I6 rpm range? might have made myself sound stupid but im curious!
