What Oil Pressure sender For Lsx swap?
I have a 1986 silverado 6.0/4l80e with a 1990 suburban cluster. Using the trucks stock sender the oil guage will read past 60psi. Tried swapping it with new sender but does same thing. Question is, should i use 1990 sender? I currently have stock sender next to oil pan, drilled and tapped oil cooler lines block.
curent sender ![]() 1990 sender ![]() if i need 1990 sender how would i go by connecting it. Since it has a 3 wire pigtail. Thanks, Jesse |
Re: What Oil Pressure sender For Lsx swap?
1990 cluster is mechanical or electrical?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
cluster is electric
Posted via Mobile Device |
