dropped spindles with 4 3/4 bolt circle
like it says in title. anyone make a dropped spndl that i can run a rotor that has a 4 3/4 bc. reason being is i ahve a garage full of wheels/mags/ralleys with this bc. oh the truck is a 67 chebbie. thanks
sorry didn't see the post by buddylee on 4 3/4 bolt cir. Last edited by b a king; 10-24-2011 at 09:02 PM. |
Re: dropped spindles with 4 3/4 bolt circle
sure we have done them in 4.3/4 " disc brakes and used s10 wheels for stock looking vehicles. Its prettty common
make sure i'm clear here. i want to put a dropped spindle on a 67 c-10 and run a discbrake that has a 5on 4 3/4 bc. i also want to put a car rear end under the truck .if you can do that. tell me what i need to buy, and where i can send you the $$$
![]() Join Date: Feb 2004
Not sure about the front rotors but i has moser make rear axles with the small bolt pattern and bought 11x2 car drums napa # ending with 1060
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
A guy with a truck
Use Belltech drop spindles for a '81-'87 LIGHT DUTY, 1" thick rotor. You will need to swap balljoints and tie-rods to the newer stuff. Run '91 Camaro 1LE rotors. They are the same as the LD rotors, but in 4.75" bolt circle...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
A guy with a truck
Conversely, Performance Online offers brackets for your stock drum spindles that convert to 4.75" discs, but provide no drop...
