Old 10-24-2011, 09:32 PM   #1
85chevy4x4
85chevy4x4's Avatar
Change
The engine is finally built in the truck after 4500 and i never thought a big metal sled would move this fast its currently 4x4 with the one an only dump truck granny 4 speed and i want to know your thoughts on putting a 2wd frame under the body and a m22 muncie behind the motor. By the way a new truck isnt an option this was my first truck and ill never get rid of it i just wouldnt mind it a little lower
85 custom deluxe 4x4 4 speed 350sb
85chevy4x4 is offline   Reply With Quote
Old 10-25-2011, 01:33 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Change
You could do that, but I'd advise re-thinking losing 4x4 capabilities. I'd rather have it and not need it than need it and not have it. If you want it to sit lower, you could get de-arched springs or something. As for the tranny, see if you can find a divorced transfer case setup from a Dodge (to keep the passenger side drop so you don't have to swap front axles), you can run the muncie transmission and keep 4-wheel drive.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
