Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-24-2011, 11:26 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Realistic effective suspension...
I'm building a 82 LWB with a 700hp big block.... I want to drive it daily, and do well at the track (4 or 5 times a year)... Is a four link something I should avoid? I would prefer to stay with leafs, and maybe Cal Tracs or something... However, If I'm going to sacrifice a second at the track, I would probably go 4 link... What are your thoughts?
Thanks!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 10-25-2011, 05:37 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Realistic effective suspension...
Lots of people been real fast on Caltracs and leafs . There are alot of 275 guys running these and putting down alot of power , plus it would be alot cheaper than a back half .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-25-2011, 06:32 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
8.32@172 on leafs and cal tracs.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 10-25-2011, 07:03 AM   #4
PGSigns
PGSigns's Avatar
Couple of things to think about. With long wheelbase what are the weight splits front to back. Mustangs and Camaro's can get real close to 50/50 on the weight and you can get weight off the nose pretty easy. When putting that much power in a long wheel base truck hook is going to be a a premium no matter what. A little more information on the complete package would help make for better answers on choices.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-25-2011, 12:08 PM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
T400, 3.50 gears, 31x10 tires, 3200 stall
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 10-25-2011, 08:37 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Nor can you beat 67-72 truck arm. Simple efffective.
Old 10-26-2011, 12:10 AM   #7
69GMC910
MOTORHEAD!
69GMC910's Avatar
I agree with the 67-72 arm deal... Just trying to keep the truck VERY road friendly, and in the 11's...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 10-26-2011, 12:50 AM   #8
Super73
Super73's Avatar
Wasnt that on an 8.5 inch tire to boot?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-26-2011, 03:43 AM   #9
BigDan3131
BigDan3131's Avatar
If you decide on a streetable but different suspension this:http://www.hotrodstohell.net/truckar...karm_index.htm is what I would do. It gives you a nice ride with the ability to adjust your springs by turning a bolt. Otherwise I would move my multileafs? inboard of the framerails and use the Cal-trac bars.
BigDan3131 is offline   Reply With Quote
Old 10-26-2011, 09:39 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Sure looks like it. But i think the 1/4 pass was on 10.5s
5.43 @ 140 in the 1/8 on 26x8.5s
Old 10-30-2011, 12:20 PM   #11
C-10 simplex
If the frame is not going to be narrowed/tubbed etc., then you could actually run both 4-link and leafs (although i would use ladder bars). Think about it.
Why not just try the no-hop bars first? Will it really be 1 sec slower?
C-10 simplex is offline   Reply With Quote
Old 11-01-2011, 08:31 AM   #12
shawnt
shawnt's Avatar
I know of a nova who has been 7.98 on leafs and cal tracs
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 11-01-2011, 08:32 AM   #13
shawnt
shawnt's Avatar
You can make the cal tracs work just fine. Save some of the.money for whatever else you may need. Tjere is a thread on yb.com called caltrac tuning or something to that effect. Lots of good info there to help you get it all sorted out.
Shawn
85 SWB
7.39 @ 93
