camper shell.....
im not a big fan of camper shells but was thinking of a wild idea. Unfortunatly i do not pocess fabricating skills nor the equipment to attempt anything.
Lets say you have a beyond repairable 60-66 chevy/gmc suburban or panel. Cut and make the top back end into a camper shell to put on a regular swb or lwb truck giving the illusion that you have a sub or panel. Am i crazy or is this a cool idea? when ever you want it to be a truck just simply take the shell off.
'66 chevy lwb c10 '65 chevy lwb c20 |
Re: camper shell.....
Sounds good! Now we just need someone to photo shop the idea so we can see it! And sub windows on the side probley would look better imo then a panel
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I was going to do this about 20 years ago, but I ended up having to move and had to get rid of my 3 parts Suburbans. It could be done with enough time and the skills to fabricate. Although I think it would be a bit heavier than a typical canopy.
That would look really cool but i would hope that you didnt have plans to remove it very often sounds like it would be pretty darn heavy
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
these are on old stepside chevy trucks, but I always thought they worked really well:
camper shell pics -W |
I've always wanted one for the stepside although I've never thought of using cutting a Sub to do it. A narrowed Sub back half....Hmmmm. Neat idea! Only negative I could think would be the weight? I think it would look way cool!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
i guess i forgot about the weight... i would still like to see a photoshop pic of it. anyone know how to do one?
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
A fiberglass shell of a panel truck would be handy, then you could insert windows or not. A lot of contouring to follow the back of the cab. A hatch at the back with or without windows. 4 sizes for each style box.
Found this in my Silver Book, the parent company still exists. ![]()
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-25-2011 at 08:22 PM. |
it might be alot of work but weight wise why dont you get a fiberglass topper and cut it up or do whatever you need to do it to with more fiberglass to make it look like the back of a panel or suburban
It would probably be best to use a sub or panel to make a mold then build it out of fiberglass.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
