Old 10-25-2011, 07:42 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Do you use gauges for your bags?
After some searching I dont find a lot of info with people using gauges to monitor bag pressure. Am I missing something? Or are they really not necessary?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-25-2011, 08:02 PM   #2
SCOTI
SCOTI's Avatar
Re: Do you use gauges for your bags?
It depends.... Some guys get a 'feel' for where they want the height & go by that. Others might have a CPU type set-up (AccuAir, RideTechs E3) that controls height via sensors that provide feedback for adjustments. The 1st method is as accurate as it sounds; the 2nd should be very repeatable.
Somewhere in between are the guys that want height 'consistency' w/o the expense of the high-end set-ups & utilize pressure gauges to monitor. While still not exact (add or subtract weight to the vehicle & it might take more/less air psi to achieve the same height), it's going to be closer than the WAG.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2011, 10:36 PM   #3
andrewmp6
All my friends who have air bags do use gauges,Most have a gauge on the tank then a dual needle for the front and back pressure or dual dual needles for all 4 bags.It comes down to budget and do you want something to play with or set a ride height and enjoy the smooth lowered height.
andrewmp6 is offline   Reply With Quote
Old 10-27-2011, 09:29 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
I always use gauges. A pair of dual needles fits nicely in the stock ash tray location. Just flip it down to see the gauges or flip it up to hide them
bagged74 is offline   Reply With Quote
