Old 10-26-2011, 12:56 AM   #1
IOWNATRUCK
Speaker wiring?
I just posted something and got help on this a few days ago, but i still have a question on the subject, I dont want to redo the wiring for speakers in my truck, but currently its just one black wire running inside a speaker behind my truck seat, would i be able to keep the wiring and just cut the speaker away from the wire and wire it to new speakers? how would i go about doing that if its only one black wire?
Thanks.
IOWNATRUCK is offline   Reply With Quote
Old 10-26-2011, 04:17 PM   #2
76stepsidechevy
Re: Speaker wiring?
Are you sure it isn't some type of coaxial wire with a shield and an inner core wire? Its really very easy to run wire to rear speakers in these trucks and a new pair of speakers might even with wire depending on what you get.
76stepsidechevy is offline   Reply With Quote
Old 10-26-2011, 05:18 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Speaker wiring?
It should be 2 wires did you look real close at it? You can make the old ones work but if your going with a new stereo might as well just put all new stuff in at the same time is my belief. Its pretty easy and not to time consuming at all.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
