Old 10-26-2011, 03:09 AM   #1
michaeltennis7
1983 C10 been Sitting since 1990 Need to make it run. Where do i start?
ok i just got a one owner 1983 gmc sierra it has a 6 cylinder 3 on the tree 2wd shortbed with only 82k orginal miles!!! but its been sitting since 1990 :[ it starts up it will barley idle and if it does it will die out a few seconds after. i can drive it but it wont go over 20mph. but it will rev up as if nothing was wrong with it??? what do you guys think???
michaeltennis7 is offline   Reply With Quote
Old 10-26-2011, 03:32 AM   #2
project 67 sub
project 67 sub's Avatar
Re: 1983 C10 been Sitting since 1990 Need to make it run. Where do i start?
rear brakes possibly froze up???
project 67 sub is offline   Reply With Quote
Old 10-26-2011, 03:34 AM   #3
paintslinga2010
I had the exact same situation with my grandpas 83. It had only been sitting since 01 though. His is a 305 though but the exact symptoms. Maybe its something similar, so I'll be watching this thread. You could try rebuilding the carb and replacing vacuum lines. I did both but neither got it to idle.
paintslinga2010 is offline   Reply With Quote
Old 10-26-2011, 07:10 AM   #4
walkerb
walkerb's Avatar
new gas?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-26-2011, 07:33 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
i would check the weights on the dizzy
remove the line from the fuel pump to the carb ,
drain and re install it
check out for cracked vac n rubber lines
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-26-2011, 12:56 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
Leaving a vehicle to sit is a lot harder on it than daily driving.
First, why was it parked? Was there something wrong with the motor like an overheating issue or a popped head gasket? Did the owner get a new vehicle and leave that one sitting? Try to find out if it ran when parked.
If it ran when parked:
-Rebuild carb - it's probably gummed up and causing the issues you're having
-ALL new fluids
-Replace all rubber hoses
-Fresh spark plugs and wires for sure, cap and rotor if needed
-Drop the gas tank and clean it, replace filter sock
-Shoot some solvent into the metal fuel lines and blow them out
-Go through the brakes completely - you just can't trust brakes that have been sitting that long
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
c10 runs bad idle
