Old 10-26-2011, 04:13 PM   #1
baggedbigblock
66 C10 Disc brake booster question
I have a 66 C10 with stock rear drums and 72 spindles/rotors/calipers up front. I was going to install a brake booster/master cylinder kit from a 72 C-10. There are about $115 online, this should work instead of buying a pricey CCP kit. I saw an mounting adapter bracket but he says this isnt needed that the firewall can be modified.
Thanks for the help.
baggedbigblock is offline   Reply With Quote
Old 10-26-2011, 04:34 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 66 C10 Disc brake booster question
Contact Captn Fab, get his mount and go to a wrecking yard and pull one off a 73-87 1/2ton truck, make sure the fluid looks good before you do and it is generally clean/serviceable. You will be out probably less than $150.00
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-27-2011, 01:01 AM   #3
Captainfab
60-66 Nut
Whether you buy a '71-'72 booster or the CPP booster/master combo, you will have to drill some holes to mount them to your truck. The booster bracket that I sell is a direct bolt on to the firewall. Then you bolt on one of the compatable boosters listed in the for sale thread, seen in the link below \/ \/ \/
Old 10-27-2011, 08:46 AM   #4
baggedbigblock
ok thanks, I am going to buy the 72 booster and see how it lines up, then I will order your bracket. I have chopped the frame, cut the small back window, shortened the long bed, so I might as well drill a hole in the fire wall!
Very nice product for a great price.
Old 10-31-2011, 05:41 PM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
I used a 1977 C20 power booster from the Local "pick-in-pull" with a 1967 Dual master.....
it bolted in with NO DRILLING. had it done in about an hour. plus bleeding the system
Total cost...$52.00
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-31-2011, 09:43 PM   #6
baggedbigblock
thanks, I am sticking with the 72, since my front brakes are from that and the rear drums where the same. I want to keep it simple, I have 66 truck, 72 suspension, 91 350/700r4 drivetrain. Should make it easier for buying parts in the future.
