Diesel driver with gasser question
I hate to have to ask, but can anyone identify what engine this is in a 1988 one ton pickup? It has two tailpipes on one side in the back if that is any help. Thanks!
Re: Diesel driver with gasser question
It is a smallblock chevy. If you want to get more in-depth, get the casting number which resides on the back of the engine, on top of the bellhousing area.
Thanks for the info, it helps me out. I don't have the opportunity to check it in person, but knowing that it is a smallblock is all I need. H.
Most likely its a 350. 1 ton's came with either a 454 big block or a 350 small block. Matt
Matt ![]() 1986 chevy K10 355, sm465/np208, 14FF/dana 44 1984 chevy K20 350, th400/np208, 14SF/10 bolt |
What Chevy355 said. Did you look for a catalyst sticker on the top of the rad support?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
You thinking of buying it or something?
![]() Join Date: Jul 2010
If it's in a 1 ton & it's org. then it should be a 350 tbi motor
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Unless it was swapped out, it is a 350 because that is the only small block offered in 1988 1 ton.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
I was looking at buying it, but it is gone. I guess I didn't really need two big blue trucks in the driveway. H.
