Old 10-26-2011, 08:47 PM   #1
coralhead
coralhead's Avatar
'47-'54 radiator frame pics
Can someone help me out with a few reference pictures? My '50 3/4 ton chevy is missing the two rod braces that attach to the front top of the radiator frame and go down to the lower radiator shroud. I believe they go down and forward and atttach near the lower grill????? ANy help with a few pictures and dimensions would be greatly appreciated. Thanks in advance.
John
coralhead is offline   Reply With Quote
Old 10-26-2011, 09:33 PM   #2
solidaxel
solidaxel's Avatar
Re: '47-'54 radiator frame pics
The only thing I remember is that one is longer than the other !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-26-2011, 09:49 PM   #3
coralhead
coralhead's Avatar
Solid.....
Do they converge off to one side on the lower shroud? I have two holes there that are set off to one side?
Old 10-26-2011, 10:41 PM   #4
mknittle
mknittle's Avatar
Originally Posted by coralhead View Post
Solid.....
they go from the firewall to brackets on inside of the wheel wells.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-26-2011, 11:34 PM   #5
mknittle
mknittle's Avatar
sorry wrong ones. i will look tomorrow we should have one i can get a pic of.
There are tow pairs one is a x brace and the other sounds like you described i tried to get a pic but it's too dark.
Mark
My GMC build.
Old 10-27-2011, 05:16 PM   #6
coralhead
coralhead's Avatar
Any luck on some pics?
Old 10-27-2011, 06:54 PM   #7
mknittle
mknittle's Avatar
Sorry about that I just remembered.
I went to my cancer doc this morning and that disrupted the whole morning.
brain cancer messes with my memory somtimes
Mark
My GMC build.
Old 10-27-2011, 07:05 PM   #8
mknittle
mknittle's Avatar
Got some hope they help, They are two trucks the 48 dosen't have the x beace but has the radator support to splash pan braces.
The other is a 52 and has both splash pan and x braces
Mark
My GMC build.
Old 10-27-2011, 07:10 PM   #9
mknittle
mknittle's Avatar
let me know if you need more.
Mark
Mark
My GMC build.
Old 10-27-2011, 08:25 PM   #10
coralhead
coralhead's Avatar
That is what i was looking for. Would it be to much to ask for the 2 lengths?
I guess i'll try and make a couple from some barstock.
Old 10-27-2011, 08:50 PM   #11
mknittle
mknittle's Avatar
sure the drivers left is 25" from the center of the top bolt to the flat where at the bottom and the right is25 1/2"
If you are going to make them I can make you a drawing tomorrow. that will help with the angles and bolt placement.
Mark
My GMC build.
Old 10-27-2011, 09:21 PM   #12
coralhead
coralhead's Avatar
That would be great. I really appreciate the help.
Old 10-28-2011, 01:12 PM   #13
mknittle
mknittle's Avatar
I was going to make a drawing but decided that pictures would be better.most of the pictures rae of the left but the right the same but shorter and the lower end turns the oposite derection.
Mark
My GMC build.
Old 10-28-2011, 01:18 PM   #14
mknittle
mknittle's Avatar
some more. oh the rod is 3/8 dimater.
Mark
My GMC build.
Old 10-28-2011, 01:22 PM   #15
mknittle
mknittle's Avatar
if you have any qustions let me know.
Mark
My GMC build.
Old 10-28-2011, 06:03 PM   #16
coralhead
coralhead's Avatar
You went above and beyond. Greatly appreciated. Thanks
Old 10-29-2011, 12:41 AM   #17
mknittle
mknittle's Avatar
it was pretty easy really, the front sheet metal was already off the truck I borrowed them from. I just took out 2 bolts.
Mark
My GMC build.
Old 10-29-2011, 07:03 AM   #18
S10Fan
Old Heap Driver
^^^^^Ditto^^^^^
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-29-2011, 10:59 AM   #19
mknittle
mknittle's Avatar
Glad to help.
Mark
My GMC build.
