Old 10-26-2011, 10:27 PM   #1
Sal's '55 Chevy
Sal's '55 Chevy's Avatar
61 Panel for my Neighbor
So my neighbor asked if he bought all the patch panels if we would do the favor and weld them in and all the exciting stuff lol. We have changed the hood and took it to the next level as far as ideas but one thing i still can't think of is lowering it. This panel does not have any springs instead it has two big bars running to the a-arms does anyone have pictures of how to lower them or if i can change to a different suspension on a budget
'55 Chevy PU 2nd Series
'97 Chevy Silverado XCab
'13 GMC Sierra
Sal's '55 Chevy is offline   Reply With Quote
Old 10-26-2011, 10:33 PM   #2
hotrod66
hotrod66's Avatar
Re: 61 Panel for my Neighbor
you can use lowering coil springs cpp makes them they are avalible from classic parts. drpending on how low you go you might need a adjustable track bar. think my springs cost me 100 bucks
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 10-26-2011, 10:36 PM   #3
Sal's '55 Chevy
see i figured i just do that but the a-arms dont have a place to put springs in it im a little confused
'13 GMC Sierra
Old 10-26-2011, 10:44 PM   #4
csa daddy
csa daddy's Avatar
its because it has a torsion bar front end in it just crank down on the bars an should lower it if any thing like any other torsion bar front end
csa daddy is offline   Reply With Quote
Old 10-26-2011, 10:47 PM   #5
Sal's '55 Chevy
i did that but im not getting the stance i want i like it might have lowered like 2 inches but is still really high
'13 GMC Sierra
Old 10-26-2011, 11:19 PM   #6
hotrod66
hotrod66's Avatar
oh sorry i was tinking rear oops. you can get drop spendals for it, also made by cpp. i dont know if they make them for the stock drum setup wich might just be a good thing then you can do disk brakes.
Old 10-26-2011, 11:20 PM   #7
72bigred
I have not tried it yet but I have the torsion set up on my 60.. I have been told I can pull out the bars and rotate it so I can achieve more drop and still have a decent spring rate.. If this is not possible I sure would like to hear.. It appears it would work..?
72bigred is offline   Reply With Quote
Old 10-26-2011, 11:28 PM   #8
Sal's '55 Chevy
i would like to know as well but i don't really understand what your meaning by pulling them out and rotating them.
'13 GMC Sierra
Old 10-27-2011, 12:10 AM   #9
72bigred
The spring rate is created by the ends that are 6 sided if I remember correctly sitting here on the couch, These sit inside the A arm, as the A arm rises the bar twists (even more than just the twist caused by tightening the bolt) causing the spring rate. If one was to pull out the bar and rotate a bit and then put it back then in theory you could either cause a rise or a sink based on the direction you twisted it. I have been told this by a couple of guys but have not pulled them out as of yet to try it.. Yet if you look it appears they are correct.. Most get rid of the torsion set up for ease of finding parts ect.. I myself want to keep it.. GM did not get away from the torsion suspension due to its quality.. No better ride in my opinion..
Old 10-27-2011, 12:20 AM   #10
Sal's '55 Chevy
IN theory that does sound correct i will try that hopefully it does something thanks if it works ill let you know if not well at least i tried and learned something new lol
'13 GMC Sierra
Old 10-27-2011, 12:48 AM   #11
losthope
losthope's Avatar
i dont know if this a deal i havent priced drop spindels and dont know how much he would charge you for shipping but keep running across these on the local craigslist but i have coil front end and figure these are for torsion bar front ends because of the years he list:
http://sacramento.craigslist.org/pts/2650610182.html
he says he doesnt want to ship them back so if it came down to it you could send me the money and ill buy them local and ship them to you but thats all up to you and if you need them or decide to go drop spindels at all....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
