Old 10-26-2011, 10:58 PM   #1
rbharris1984
First Truck
Hello all,
My first swb and first post. I hope to find lots of info and want to say thank you in advance. Traded a 1998 jeep cherokee for a 1982 swb that is in need of some work. Couple questions, first is if this truck came with a 10 bolt 8.5" posi rear from the factory and I'm having a knock around cylinder 6 that i can feel in the valve cover. It is only when idling and doesnt affect driving but it is very noticeable. I had a misfire so i replaced plugs and wires which solved the problem of misfire only to have a knock the following day. I drain the oil which has no metal in it and removed valve cover, had my wife tap the ignition and everything seems to be moving freely. I'm just wondering if something could have been stuck or needs adjusting. I have searched and searched the internet and forum. I dont even know if it is stock because it has aftermarket intake manifold, carburetor, and has a nice lope when idling. Sorry if it's too in depth or repeated.
rbharris1984 is offline   Reply With Quote
Old 10-27-2011, 12:53 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: First Truck
you can run the motor for a short time without the valve cover on it, it will make a mess but that way you can tell if you have a sticking valve or rocker arm messed up, also did you do a comp check on that cylinder?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-27-2011, 07:45 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: First Truck
Yes, the truck came with a 8.5" ring gear 10 bolt, but a Posi was optional so you may or may not have it.
You can check your SPID label, in the glove box (?), and look for RPO "G80", which was the option for the "non open" rear diff.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
