10-26-2011, 11:14 PM | #1 |
Air ride shock help
Hay guys Im needing shocks for my 62 swb it has a full air ride suspension with a four link in the rear it almost lays frame.. what is the propper way to measure for shocks do i measure at full extension of the bags or just at ride height.....
THANKS for any help you can send my way |
10-26-2011, 11:35 PM | #2 |
It's Better With Nitro
Re: Air ride shock help
I always take my measurements at the ride height and take into account how much suspension travel I want. Then I use a shock with that height as the middle of the shock travel that does not bottom or top out before my projected suspension travel.
10-26-2011, 11:37 PM | #3 | |
Full air suspension including custom shock mounts or??
10-26-2011, 11:41 PM | #4 |
I have stock mounts in frount and custom mounts in back
10-26-2011, 11:55 PM | #5 |
Use different upper mounts for the fronts. They'll allow a longer shock to be used which gives better ride quality (greater extension & compression before bottoming out) & should increase your shock options.
