Old 10-27-2011, 08:48 AM   #1
m38joe
suburban sliding side windows
Has any body tried the wheatherstrip kit from classicparts for the sliding windows on a suburban? is it complete and does it fit?
m38joe is offline   Reply With Quote
Old 10-27-2011, 09:00 AM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: suburban sliding side windows
i did the set from brothers without any problems it just took a long time to do each window
gostranger is offline   Reply With Quote
Old 10-27-2011, 05:00 PM   #3
65burban
I have heard the best kit is from STEELE rubber.
65burban is offline   Reply With Quote
Old 10-27-2011, 05:08 PM   #4
gostranger
gostranger's Avatar
I believe that is true but they are more expensive also.
Old 10-27-2011, 06:33 PM   #5
LT1 Burb
LT1 Burb's Avatar
Don't use anyones but Steele's, unless you want to throw tools across the garage, punch the wall and scream like a little girl.
LT1 Burb is offline   Reply With Quote
Old 10-27-2011, 07:13 PM   #6
65burban
Talking Re: suburban sliding side windows
LT1: is that why you had to build a new garage??? (j/k)
Old 10-27-2011, 07:23 PM   #7
padresag
but doesn't that usually go hand in hand
ron
padresag is offline   Reply With Quote
Old 10-27-2011, 09:00 PM   #8
m38joe
Was the brothers kit complete? I have four slides to do and don't want to order a kit that doesn't fit or have all the rubber. All my rubber and felt are shot.I'm rebuilding all the channels. I didn't think they were that bad til I got them out
Old 10-29-2011, 12:19 PM   #9
csa daddy
csa daddy's Avatar
is there any diff between a solid window frame an a slider window frame besides the rubbers
csa daddy is offline   Reply With Quote
Old 10-29-2011, 01:03 PM   #10
protrash64
Resistance is Futile
protrash64's Avatar
Yes. There is no frame on a solid window. Its held in with only the rubber and you need spacers below the rubber to center the window in the opening.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-29-2011, 02:23 PM   #11
LT1 Burb
LT1 Burb's Avatar
If you want to try the Brothers kit then first do this, get a solid piece of 1X1 rubber, cut a 120 degree miter by hand and then fold it over to make a perfect contour shape, and do it twice in one piece with 2 smaller angles, or just order from Steele and they do it for you.
Old 10-29-2011, 07:41 PM   #12
FreakyMalo
FreakyMalo's Avatar
I got lucky; my project included Steele Rubber for all 4 sliders. I need some felt to do it right. Does anyone have a source or should I just hit the local upholstery shop?
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 10-29-2011, 07:44 PM   #13
protrash64
protrash64's Avatar
I only made one cut per window using the Brothers kit. I wrapped the glass tightly and taped it down and when I reached the corner I cut both ends of the seal to fit. Installing the glass wasnt too bad but not fun either!! I agree that Steele makes excellent pieces. I need to redo some glass and may order from them. I just dont find glass a good time but I hate paying people to do what I can.
Old 10-29-2011, 09:34 PM   #14
dthela
dthela's Avatar
what felt? the one that slides into the vertical track between the windows? i have some! I need a piece of the small s shaped rubber that goes around the glass and over the painted lip on the outside!!!!!!!!!!
dthela is offline   Reply With Quote
Old 10-30-2011, 12:49 AM   #15
FreakyMalo
FreakyMalo's Avatar
The felt that goes inside the frames on the quarter window sliders. Keeps the glass off the metal.
66 Carryall
my photos
Old 10-30-2011, 06:56 PM   #16
FreakyMalo
FreakyMalo's Avatar
Is it window-run channel like you'd use in the doors?
66 Carryall
my photos
Old 10-31-2011, 04:31 AM   #17
dthela
dthela's Avatar
yes the sliders take window run, but if i'm not mistaken the slider stuff is wider. What I'm looking for usually comes in the kit. its sorta s shaped goes between the fixed slider and the body. need enough for one window.
Old 10-31-2011, 07:41 AM   #18
csa daddy
csa daddy's Avatar
are the back sliders the same as the front sliders frame an all
Old 10-31-2011, 07:55 AM   #19
m38joe
No. all the sliding frames are a different shape. A left front will not fit a right rear.....
Old 10-31-2011, 08:09 AM   #20
csa daddy
csa daddy's Avatar
grrrr
Old 10-31-2011, 11:43 AM   #21
64fleetside
The front & rear windows are similar enough you could use fronts for rears if you cut off the mounting tabs & rewelded-basic shapes are the same. The front drivers would fit the rear pass, etc.
64fleetside is offline   Reply With Quote
Old 10-31-2011, 01:47 PM   #22
csa daddy
csa daddy's Avatar
o ok thanks
Old 10-31-2011, 09:08 PM   #23
protrash64
protrash64's Avatar
This info is incorrect unless you want to build complete frames out of the original front frames. I completely changed my glass to solid and the front does not match the rear. I will attempt to set up a pic to show the difference.
Old 10-31-2011, 09:15 PM   #24
protrash64
protrash64's Avatar
Here is an ORIGINAL rear glass piece on top of a template I made from my FRONT window frame......the difference in contour is evident.
Old 10-31-2011, 09:25 PM   #25
64fleetside
I dunno-I got all 4 windows, they will fit in the front or the rear holes in my burb, only the mounting tabs are in different places, but maybe yours is different. The front pass fits the driver's rear, etc.
