Old 10-27-2011, 10:54 AM   #1
gettmoneyy7
gettmoneyy7's Avatar
how do i do the cnotch for 6inch drop on my 86 shortbed?
If any of you guys can help me i appreciate it. i have a nother rear end set up for the 6inch drop on my 1986 c10 shortbed just not sure how the cnotch works .
gettmoneyy7 is offline   Reply With Quote
Old 10-27-2011, 11:03 AM   #2
SCOTI
SCOTI's Avatar
Re: how do i do the cnotch for 6inch drop on my 86 shortbed?
The c-notch bolts-in (or welds in) just above the center-line of the rear end axle tubes. You want to center the notches w/the rear end attached to the springs & up against the bottom of the frame rail.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2011, 11:11 AM   #3
gettmoneyy7
do you have to cut out the bed in order to do the cnotch with the flip kit on the rear end?
Old 10-27-2011, 11:45 AM   #4
SCOTI
SCOTI's Avatar
No cutting of the bed is necessary for up to 8" drops (flip-kit + dropped shackles). The c-notches do allow for more drop which in turn allows the rear end differential housing to get closer to the bottom of the bed floor (keep that in mind).
This would be for most 'common' bolt-in style c-notch kits (some could be different). Bell Tech, Western Chassis, DJM, & McGauhy's should not require cutting the floor.
Bolt-in or weld-in step notches will require cutting the floor.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-27-2011, 01:13 PM   #5
gettmoneyy7
is it possible you point me in the direction of some pics of it so i can see what i have to cut on the frame for the c-notch to be installed because i was looking around and can't find any. id appreciate it.
Old 10-27-2011, 08:33 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
this will help you out
http://73-87.com/7387garage/chassis_...n/csection.htm
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-28-2011, 11:30 AM   #7
gettmoneyy7
thanks i appreciate it..
Old 10-28-2011, 03:21 PM   #8
gettmoneyy7
How do i figure out what the gear ratio is in my other rear end thats sitting out of the truck before i put it in ? and i was told it was posi ..how can i make sure before its in.
Old 10-28-2011, 03:30 PM   #9
jimmydean
jimmydean's Avatar
Pull the cover and count gears. You will also see if there is a posi unit in it or not. Plus you can change the oil and make sure everything looks good.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-28-2011, 05:18 PM   #10
gettmoneyy7
I just opened it up . heres some pics of the inside. what am i looking for to tell me if its posi ? its a 2.73 rear end from the numbers on the gears (41 - 15)
