Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-27-2011, 07:30 PM   #1
Jparks
Jparks's Avatar
Mi:427
You've got 10 grand(but dont have to use it all) and need to build the baddest streetable 427 sbc you can. No turbos or supercharges here. This is from carb to oil pan. You're already working with a built 4 speed tranny, 4.10 gears and 29" tall tires. You have your headers, march pulley system and the mounts on your custom suspension set up are for a sbc so no ls or bbc is in the cards. You want it pretty agressive but also reliable. What parts do you use, what is your estimated numbers for the engine and who do you get to build it for you. Thanks in advance engine gurus.
Jparks is offline   Reply With Quote
Old 10-27-2011, 08:26 PM   #2
djracer
djracer's Avatar
Re: Mi:427
First things first. Don't even consider using a stock block!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-27-2011, 08:27 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Mi:427
10 g ,i would find a cheap engine on cl and go to vegas with the rest ,thats the way i roll
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-27-2011, 08:32 PM   #4
djracer
djracer's Avatar
Re: Mi:427
Hyd roller stick, nice set of aluminum heads, dart, brodix, afr, Bullet Proof bottom end, Forged Pistons, ultra Hp holley 750, Dart Block
Particulars would depend on exactly what you have in mind for the truck.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-27-2011, 08:40 PM   #5
Jparks
Jparks's Avatar
Re: Mi:427
I found the engine below through a few referrals. It's at a place called White Racing and Machine in Kingsport, TN. They've been around since 79 so they must be doing something right. Not sure how reliable or correct the numbers are.
1, DART 4 BOLT SPLAYED CAP MAIN BLOCK BORED 4.125 AND PLATE HONED FOR MAX PERFORMANCE, MAINS ARE ALIGN HONED,BLOCK IS MACHINED ON CNC MILL FOR STROKER CRANK. THIS BLOCK IS PREPARED THE SAME AS OUR RACING ENGINES.
2, EAGLE,OR SCAT, 4.000 STROKER KIT , EAGLE RODS OR PRO COMP, H ,BEAM ,6.000 LONG, PROBE FORGED PISTONS AND MOLY RINGS
3, BALANCED AND BLUE PRINTED TO OUR SPECS.
4, ENGINE HAS LUNATI OR CRANE CAM .615 LIFT, HYD. ROLLER.
5, MELLING HIGH PRESSURE PUMP MELLING TIMING SET.
6, STAINLESS STEEL FULL ROLLER ROCKERS 1.6 OR 1.5 RATIO,
7, THIS ENGINE HAS DART 230 ALUM. HEADS 2.08-1.600 S/S VALVES.
8, THIS ENGINE WILL MAKE 600 HP, I WILL FURNISH DYNO SHEET FOR ENGINE,ALL ENGINES ARE RUN ON THE DYNO TO VARIFY HP AND TORQUE, WE CAN EMAIL SPEC. SHEET AND DYNO SHEET ON REQUEST.
9, ENGINE COMES AS YOU SEE IT IN PICTURE ,850 QUICK FUEL DOUBLE PUMPER..
10, ENGINE COMES WITH CROSS WIND ALUM. INTAKE OR SINGLE PLANE FOR COMPETITION RUNS.
11, NEW HEI DIST. ,PROCOMP WIRES, CHAMPION PLUGS, ENGINE COMES AS YOU SEE IT WITH A ,850 QUICK FUEL DOUBLE PUMPER .
12, ENGINE IS READY TO RUN TIMING IS SET,VALVES ARE ADJUSTED, [ WE DO OFFER UP GRADES]
13, THIS ENGINE WILL RUN ON 92 OCTANE,10.9 COMPRESSION RATIO.
Old 10-27-2011, 11:34 PM   #6
Captainfab
60-66 Nut
Re: Mi:427
I'm no engine expert, but I liked everything I saw until I read 'Pro Comp'
Old 10-28-2011, 06:13 AM   #7
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Mi:427
I have bought parts from Skip White, he's big on the Ebayer sellin. He sells ALOT of Pro-Comp stuff. Matter of fact a buddy of mine is runnin his SS roller rockers on a 406. If I'm not mistaken, he's a racer himself. I kinda like the description but like djracer said, it's all in what you want the motor to do. Have you talked to Skip to get more specifics on the motor? I think the cam size listed is to small for one. See if he can build the motor with your specs. for the same price & you get your own dist., wires, plugs etc.... JMO
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 10-28-2011, 07:09 AM   #8
djracer
djracer's Avatar
Re: Mi:427
check with these guys http://www.sunsetracecraft.com/ They are in lubbock. They mostly do big block stuff. I have heard good things about them.
I would avoid the Pro Comp stuff.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-28-2011, 07:16 AM   #9
Jparks
Jparks's Avatar
Re: Mi:427
Thanks guys for the input, I'm going to call both places today
