Old 10-28-2011, 11:52 AM   #1
jserrato714
jserrato714's Avatar
what drive shaft too use?
Hey there forum..So I have a 63 suburban with a 350 sbc and a 350 trans...The trans tail housing appears to be a long one measuring 9 1/4 long. My rear end is still the original. I need a 1 piece drive shaft that measures 55 1/4 long or a bit smaller. Anything out there thats straight bolt on? Maybe a junk yard set up? Please help thanks
jserrato714 is offline   Reply With Quote
Old 10-28-2011, 02:36 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: what drive shaft too use?
One of the things I don't cut corners on (safety equipment is another), is the driveshaft, particularly for the price (~$280) v. potential savings of modifying a used shaft compared to the damage/safety concerns - I would just rather save a few bucks elsewhere. Since he is not too far away, I would highly recommend contacting Wade at Drivelines Incorporated and talk with him about your application, etc.
http://www.drivelinesinc.com/
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-28-2011, 02:42 PM   #3
'63GENIII
'63GENIII's Avatar
^^^ Ditto! Having one come apart on the freeway taught me that lesson quickly. A good shop can turn a quality one out quickly. One less thing to wonder about while youre driving.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-28-2011, 05:35 PM   #4
jserrato714
Thanks guys...Your right...Safety first....I will give him a call..Thanks again.
Old 10-28-2011, 05:58 PM   #5
jserrato714
I called over there but wade was busy so I spoke to another dude..he quoted me for 340 out the door which I think is fair. He was asking me about the u joint for the rear . He asked if I knew the size which I dont. Any ideas what size joint I need ? Its the stock differential that came with the 63 burban. I was thinking of just calling auto zone and asking If they carry it for that year and getting my info there.
Old 10-28-2011, 06:30 PM   #6
vin63
vin63's Avatar
Yeah, I read over your first post and realized that that will be a very long driveshaft. You'll have to provide pretty specific measurements, so I would also measure the yoke, but I would imagine it is a 1310.
Here is what I use to have new driveshafts built.
http://markwilliams.com/Images/DshaftOrderLg.jpg
