Old 10-28-2011, 01:36 PM   #1
56 3100
56 3100's Avatar
55-59 with bench seat and lokar shifter pics?
i already have a tilt column with no shifter and key. any one have a 55-59 with a bench seat and a lokar shifter please post up your pics. in regards to an automatic shifter i am thinking about using a 16" or 23" nostalgia shifter or regular 16"or 23". i am using a 88-96 chev truck seat shown in my cab below pic. any one know length of original 4 speed handle that had single bend. i have sold trans so i cant measure mine. thanks
george
56 3100 is offline   Reply With Quote
Old 10-28-2011, 03:11 PM   #2
SHORTDOG99
Re: 55-59 with bench seat and lokar shifter pics?
What did that steering column come out of? and is that seat out of a regular pick up? or burb, tahoe, ??
SHORTDOG99 is offline   Reply With Quote
Old 10-29-2011, 12:45 AM   #3
dcmalone
dcmalone's Avatar
Unfortunately I don't have the seat mounted yet, but it is out of a 88-96 work truck. The shifter is a 32" radical from Lokar. This only helps you halfway, sorry.
dcmalone is offline   Reply With Quote
Old 10-29-2011, 10:13 AM   #4
judd55
Were you able to mount that shifter with the trans installed ?
judd55 is offline   Reply With Quote
Old 10-29-2011, 08:32 PM   #5
dcmalone
dcmalone's Avatar
Yep, the transmission cover was out because I bought a new one. Since it was a column shift originally the cover didn't have a hole for the shifter. Once the shifter was installed I measured what size opening I needed and cut away. I was really impressed with the ease of install with the Lokar, it was a direct bolt on. Only had to trim the shift rod an inch or so. I've also wired the nuetral safety switch on the shifter...too easy.
Old 10-29-2011, 08:50 PM   #6
mknittle
mknittle's Avatar
I wish I had a nickel for every shiftier Lokar has sold!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-29-2011, 09:07 PM   #7
judd55
Thanx, apprecciate the info.
Old 10-29-2011, 10:58 PM   #8
56 3100
56 3100's Avatar
hey short dogg i have an i didit column seat is out of 89-96 chev truck. hey dc
32" shifter cool but to tall for me.
Old 10-30-2011, 12:06 AM   #9
dcmalone
dcmalone's Avatar
Not a problem, good luck with the project.
Old 10-30-2011, 12:07 AM   #10
dcmalone
dcmalone's Avatar
It's definately up there in height and requires a certain taste. I almost bought a shorter one, but I kinda like the above the dash look too.
Old 10-30-2011, 12:08 AM   #11
dcmalone
dcmalone's Avatar
You and me both!!
Old 10-30-2011, 06:55 PM   #12
entourageguy
Yellow truck club
entourageguy's Avatar
I used the longer one
32" I think with the double bend to keep it a bit farther away from the middle person on the seat.88-98 pickup
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-31-2011, 10:26 PM   #13
dcmalone
dcmalone's Avatar
Attachment 821424
Wow, year 2080 and the truck still looks amazing, j/k. I've seen pics of your truck before and realy like it. I think yours is the reason I went with the seat I did. Mine had head rest originally but left them off on the recover.
Old 11-01-2011, 06:38 PM   #14
Barney Rubble
Barney Rubble's Avatar
entourageguy has the LMC flux capacitor fitted to his truck.
Barney Rubble is offline   Reply With Quote
Old 11-01-2011, 08:21 PM   #15
entourageguy
Yellow truck club
yes it works well.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
