Old 04-16-2003, 09:59 PM   #1
bigjimzlll
bigjimzlll's Avatar
crazylonghorn????
hey man...hows the 6 speed doing...been able to give it a good romp yet?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-16-2003, 11:21 PM   #2
crazy longhorn
Fabricate till you "puke"
Hey, shes rollin good! I havent run but a tank of fuel through the truck, & have been doing a little recurve on the dist(the curve was a bit fast without that loose converter). I dont have enough miles on to let it rip yet, but the trans is starting to limber up on the shifts. eng balance "feels" good with the 400sb flywheel(I was sweatin that for a while). A couple short hops on the hyway showed 70 mph @ 2500 on the tach(not bad for 4.10 gears!). Its a lot more fun to drive than that auto trans I lost a baffle in one of the superturbos(rattle), so the 40s Flows went back on, & rear exit tail pipes. the old truck has been keepin me busy! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
