Old 10-28-2011, 03:35 PM   #1
stang3191
how to remove a trans from a 90 cheyenne
hi guys my trans went out and i never removed a trans before are they easy or hard to do.
mine truck is a 90 cheyenne 2wd 4.3 v6 5 speed
thanks for any help
stang3191 is offline   Reply With Quote
Old 10-29-2011, 11:06 AM   #2
truckdude239
truckdude239's Avatar
Re: how to remove a trans from a 90 cheyenne
umm fairy easy
1. disconnect battery
2> remove starter
3. disconnect linkage, and tv cable
4. remove drive shaft
5. remove inspection cover
6 unbolt torque convertor
7. support the trans
8 loosen the bell housing bolts
9. loose and remove cross menber from trans
10. slide the trans back and lower out
to install just follow backward just make sure your torque convertor is fully seated
also make sure to reset the tv cable with the new trans if it is a 700r4 a misadjusted tv cable will burn up a transmission in about 10 mins
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-02-2011, 04:57 AM   #3
lurch115
lurch115's Avatar
Originally Posted by truckdude239 View Post
umm fairy easy
2> remove starter
isn't the 5 spd behind a v-6 a stick?
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-02-2011, 11:21 PM   #4
bloertcher
bloertcher's Avatar
I did my first one at 17,omit the torque convertor/tranny lines from the previous post,and you have it.
Take a few minutes to unscrew the shift boot,and pull the 4 10mm bolts that takes the shifter assembly off,makes life much easier.
RIP Baby Jack 2-06-07
See You On The Other Side My Little Man
bloertcher is offline   Reply With Quote
