10-29-2011, 12:19 PM | #1 |
1972 C10 Rear Bag Mount Concepts and Ideas
Can you guys post some images and ideas for rear bag mount locations?
I'm bagging my sons 72 Chevy C10 and it has a leaf setup but I'll be ditching that. Lookin for an alternative setup, 3-link, 4-link...etc. Need to know the best place for mounting the bags and how/where to mount them. |
10-29-2011, 04:22 PM | #2 |
Laid Lo
Re: 1972 C10 Rear Bag Mount Concepts and Ideas
It all depends on your skills and what your after namely how low do you wanna be?
I think the best riding set up is the bags on the bars. This will also give you more lift than just the height of the bag. I'm a triangulated four link fan, but most real handling and performance guys don't care for them. Works for me as mine is cruiser. I chose a kit for mine. Sleeve bags behind the axle ride pretty good. A backhalf is not a bad idea if you got the skills and time. Here is a simple sleeve bag setup that I think is very clean. http://67-72chevytrucks.com/vboard/s...d.php?t=338392 If you aren't trying to lay frame check out how N2TRUX's black square body used to be setup. One of the best examples of a leaf sprung truck with bags. Nice and low, clean and simple. Lastly bag over axle setups. They ride way to stiff for me so I wouldn't consider them.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
10-29-2011, 07:13 PM | #3 | |
We will be dumping the leaf springs...... |
10-30-2011, 01:53 PM | #4 |
Laid Lo
No it wouldn't be hard to do and if you go through the build threads there are a number of similar setups with square tube lower bars.
10-30-2011, 06:55 PM | #5 |
67-72 parts collector,…
Ditch your leaf springs and swap to trailing arms.
10-30-2011, 07:23 PM | #6 |
low n' slo
i have bag over axle with trailing arms and 2" drop block...havent rode in it yet so i cant tell you about the ride.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-30-2011, 08:00 PM | #7 |
10-30-2011, 08:23 PM | #8 |
Laid Lo
I think he was referring to the factory trailing arms.
10-31-2011, 07:41 AM | #9 |
12-31-2011, 08:25 PM | #10 |
Any good pictures?
Posted via Mobile Device |
01-06-2012, 05:05 PM | #11 |
Talk to Nate at Porterbuilt fabrication. Www.porterbuiltfabrication.com. He has a bunch of different kits mild to extreme.
