10-30-2011, 09:31 AM | #1 |
1963 C-10 BBC/Muncie 4 spd
door not closing tight
I've searched on door adjustment here but I still don't understand so hopefully someone can explain it to me in dummy terms.....My drivers door latches but doesnt close tight, it is about 1/4" ajar. As you know, there is no adjustment in the latch or door striker, so how on earth do I make my door shut tight?????
10-30-2011, 11:47 AM | #2 |
Re: door not closing tight
There i some adjustment on the stiker. Losen up the 4 bolts and tap it in a bit. It wont be much but it might help. If you close the door and latches but still moves in an out if you tug on it adjust striker. If its fully latched but doesnt move when you pull on it it could be the weather strip not allowing the door to close flush with the cab.
'66 chevy lwb c10 '65 chevy lwb c20 |
10-30-2011, 12:01 PM | #3 |
Well, it does latch but I can jiggle it. When you say to adjust the striker, thats where I dont understand. I loosened the screws and there is no movement so what am I adjusting?
10-30-2011, 12:08 PM | #4 |
you need to adjust the wedge on the lower part of door
10-30-2011, 12:11 PM | #5 |
The striker has glue or some type of sealant. After you losen the bolts pry the striker from tha cab. This will allow you to move it around a bit
10-30-2011, 01:01 PM | #6 |
Just here to tinker
Also, there should be two distinct "clicks" when you close the door slowly. If you are only getting the first one, then that is why it is jiggling a bit. But, as mentioned above, adjust that striker pad to let the door move in. What I found out in my old '60 was that you'd have to slam the door to get two clicks but then I realized there was slack in the inside door handle and if I took that slack out and then closed the door, it would shut super nice. These old worn out mechanisms will toy with you.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
10-30-2011, 01:31 PM | #7 |
Visual aid.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
10-30-2011, 02:29 PM | #8 |
Again getiing the wedge adjusted first then adjust striker
10-30-2011, 02:44 PM | #9 |
OK, I'll check and fiddle with it. Sorry to sound like a dummy!
10-30-2011, 03:47 PM | #10 |
Sucess! The two click thing eluded me...lubed it up, played with the striker and BINGO! Another thing off the list!
10-30-2011, 04:07 PM | #11 |
cool
10-30-2011, 10:36 PM | #12 |
1961 crewcab
this is what I did too , worked wonders
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
