C10 CLUB Y QUE!
brake issue on 65 conversion
i just changed from drums to disc. used early classic drop spindels, replaced ball joints.
but adding my brake booster and Mc theres a rod issue. the rod for the old MC is alot longer than the rod for the brake booster. any idea on how every one does this ill post pic if needed thank you |
Re: brake issue on 65 conversion
Dont have pics but some weld to proper length. I used A mc from a 76 c10 and used an adjusting nut to lengthen the pushrod. Same principal as tie rods. An adjusting sleve turned one way will spread the tie rods apart and pull them in when reversed.
'66 chevy lwb c10 '65 chevy lwb c20 |
C10 CLUB Y QUE!
here some pics
Wow thats a huge difference. Is it posible to use your original pushrod and just lengthen it? If the mc is a universal type there may be adaptors for proper length. Srry couldnt be of much help
C10 CLUB Y QUE!
That's ok Shawn came by and we cut.and welded the.end to it.
Now were can I get bonjo bolts for the caliper. Kragen and AutoZone have one in stock but it is short and thin Posted via Mobile Device |
C/10 junkie
Try Vic. Haha
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
C/10 junkie
Didn't the banjo bolts come with the calipers?
C10 CLUB Y QUE!
No but ill cal AutoZone and see if they do
C/10 junkie
If not there is that place right on the other side of the freeway on charter next to taco bell has all kinds of stuff like that. I think it's called j and m or something. It's a farmers hardware store. Has a lot of goodies.
C10 CLUB Y QUE!
Nope
C/10 junkie
I will take a look at work tomorrow and see if I can find a couple. Hope they will fit.
You have a Napa store there..?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#13 |
C10 CLUB Y QUE!
Yah we do but not open on Sunday when I needed them
#14 |
If worse comes to worse go to pick an pull....
