1970 C20 Windshield INstallation
Hey guys, quick question. I am going to be replacing the front windshield today or I am in the process of it. I have a new seal/gasket and am using the rope method. I am having some issues as it seems to be a rather tight fit.
Do you place the windshield and gasket on the bottom rail and seat it first then work your way around to the top or top to bottom? I used plenty of soap and water on the gasket so it shouldn't be this difficult. Maybe this is why the other guy had glued the windshield on before me.... |
454 MAKES IT ROAR
Re: 1970 C20 Windshield INstallation
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
here is one video. I think will help more than a thousand words.
Pancho 69 c/10 step side 454/400 with 3.07 |
![]() Join Date: May 2011
Cool. I need that soon. In my favorites Now!
Sweet..... Thanx
![]() Join Date: Jan 2008
That's a good video. You might also need a cotter pin removal tool to help pull the rubber over the pinchwelds, especially in the corners. Also, some light slapping with an open hand as the rubber starts to lay in place, helps. Make sure you stay behind the rope if you gently slap it. The bottom also has like a double lip, make sure it is pulled all the way over the bottom pinchweld. Good luck!
