Old 10-30-2011, 08:10 PM   #1
71 super
71 super's Avatar
Help needed on AM/FM
I replaced the orig. AM radio in the 68 with a factory AM/FM I had, would light up but not play, ok thinkks I radio bad, fast forward to today. I installed a known working AM/FM unrestored - no lightes sound etc. , then I replace this one with a restored version from Radio rescue (yes three factory am/fm's) and same thing. I realize that there is an issue just dont know what it may be. Fuse is intact but no power showing up at radio. Any suggestions before I tear into this.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-30-2011, 08:15 PM   #2
big mike71
big mike71's Avatar
Re: Help needed on AM/FM
Mine lit up but no sound, It was a speaker wire grounding out.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 10-30-2011, 10:46 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Double check your connections. Make sure the wires are not broken as mentioned above and insure you have a good speaker and antenna connection. The antenna, if it's an aftermarket, sometimes won't make good contact.
68gmsee is offline   Reply With Quote
