10-30-2011, 08:52 PM | #1 |
WTB Brake Line Brackets
I am looking for the right and left side front brake line bracket for a 72 C10. It's the bracket that holds the steel line and the rubber line on the crossmember. You'll have to drill the spot welds, torch or cut around the bracket and I can drill out the spot welds. Thanks, Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
10-30-2011, 09:02 PM | #2 |
Re: WTB Brake Line Brackets
I have a 71 frame, will that be the same ? or not
10-30-2011, 09:08 PM | #3 |
Its most likely the same since it has factory disc brakes. When do you think you'll be able to check to see if its the same?
10-30-2011, 09:18 PM | #4 |
I will look tomorrow, hopefully my shop will have power restored by then....
10-30-2011, 09:24 PM | #5 |
We got a little snow but its all gone now, not enough to take out the power Let me know if you can help me out, price shipped to 15227. Thanks, Nate
10-30-2011, 09:38 PM | #6 |
Will do Nate
11-02-2011, 07:47 PM | #7 |
Hi Nate
The front was taken out from that frame but have another coming in a few weeks and will look at that one. If it has the correct ones I will pull them.... sorry for the delay this week I've just been run over.. Last edited by Pro Metal Shop; 11-02-2011 at 07:57 PM. |
11-02-2011, 08:38 PM | #8 |
Thanks for trying to help out Thanks, Nate
11-02-2011, 08:41 PM | #9 |
Anybody else willing to part with a set of these brackets I know they will be a pain to get off but you'll be helping me out big time I'm going to be sending my frame out for powder coat soon and would like to have these welded on. Thanks, Nate
11-03-2011, 10:26 PM | #10 |
ttt
11-03-2011, 11:08 PM | #11 |
Just a Member
I have a set... Let me get them off tomorrow and I will let you know buddy!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
11-04-2011, 05:54 AM | #12 |
Before you work on getting them off do you want to shoot me a price shipped to 15227. Also can you post a pic to see if we are talking about the same parts. The brackets are spot welded to the front crossmember above the coil springs. Thanks, Nate
11-04-2011, 06:11 AM | #13 |
67-72 parts collector,…
If you can't find any,... I would look at something like these:
http://www.summitracing.com/parts/LNG-45283/ Better yet,... just make your own.
11-04-2011, 06:13 AM | #14 |
11-04-2011, 01:01 PM | #15 | |
11-05-2011, 02:17 PM | #16 |
Did you get a chance to look for the brackets?
11-05-2011, 02:49 PM | #17 |
Just a Member
Yeah...looks like this def needs power washed lol
11-05-2011, 02:50 PM | #18 |
Just a Member
Are you wanting original parts??? not copping out but you might be better buying new.. By the time it takes to clean up and take off... You know?
11-05-2011, 02:58 PM | #19 |
No, I don't need original for the frame. It's not a problem I'll go for the new ones. Thanks, Nate
